Hey all! Looking to get back into the swing of things with a GTW GP38-2 build. The Grand Trunk units did not have dynamic brakes, and as we know the early Weaver models came from the factory with them. Are the side housings removable or does the entire hood section need to be removed and replaced? I am really hoping to not have to cut and patch the body more than I absolutely need to. (I assume the DB fan will need to be cut out)
Thanks!
Weaver GP38s
Re: Weaver GP38s
Here you go.
You do have to fuss the fan off or you could saw off the airbox then build a new after-section of styrene, but this shows how it comes apart and the component bits.
Helpful?
Helpful?
ogauge47
Re: Weaver GP38s
The Weaver is actually a 38-2 while the K-line an earlier GP38, the wider spacing of the after fans are the big tip-off, just so you're aware of it (You probably are, but mentioned just in case). Not a bad match for the GTW 4900 series. Watch the trucks as the Weaver are earlier outside hung brakes and no snubbers. At least some of GTWs units had them so you should be good so long as you check which one you're doing.
Shoving the horn back off the cab would be easy and well worth doing for "the look", too.
I've never had occasion to work with the K-line, but the Weaver shell is nice to work with, actually.
ogauge47
Re: Weaver GP38s
sarge wrote:The Weaver is actually a 38-2 while the K-line an earlier GP38, the wider spacing of the after fans are the big tip-off, just so you're aware of it (You probably are, but mentioned just in case). Not a bad match for the GTW 4900 series. Watch the trucks as the Weaver are earlier outside hung brakes and no snubbers. At least some of GTWs units had them so you should be good so long as you check which one you're doing.
Thanks for the info! The Weaver should be perfect then. The 4900’s were ex-MP units with the leaf spring Blomburg trucks, outside brake hangers and wide spaced fans. The one detail to add would be the additional jack pads underneath the cab.
