Suggestions for headlights, number boards, etc.
Postby up148 » Fri Jun 12, 2026 12:59 pm
Looking for suggestions for micro incandescent lights or maybe LED's. Not sure if LED's look correct. Headlamps, number boards, cab lights, etc. Cir-Kit wants almost $5 for each light which is a bunch.
Re: Suggestions for headlights, number boards, etc.
Postby Rufus T. Firefly » Fri Jun 12, 2026 3:30 pm
Try Evan Designs for LED lighting supplies -- https://evandesigns.com/
Postby up148 » Fri Jun 12, 2026 3:40 pm
Looks like a good place to buy LED's, connectors and who knows what else. Thanks! :)
Postby webenda » Fri Jun 12, 2026 4:29 pm
up148 wrote:Looking for suggestions for micro incandescent lights...
May I suggest micro incandescent light bulbs sourced from Etsy, eBay, or Amazon?
Dan Dawdy wrote an article on making realistic headlights in OSR.
The O Scale Resource July/August 2014 Pgs 62-65
Locomotive Lighting
by Dan Dawdy
Postby up148 » Fri Jun 12, 2026 5:44 pm
Thanks Wayne, your suggestions are always appreciated. I will also find the article Dan did in OSR.
Postby up148 » Fri Jun 12, 2026 5:53 pm
up148 wrote:Thanks Wayne, your suggestions are always appreciated. I will also find the article Dan did in OSR.
Update, I found the article (Dan makes it so simple) and it's very informative. I printed it off and will start planning my light conversion. Thanks again!
