Recommendation wanted for wire rope
Postby G3750 » Wed May 17, 2023 10:18 pm
Hi All,
I'm looking for something heavy-duty to simulate wire rope. EZ-Line, even the Heavy Duty variety, is just too thin. The wire rope will be used to hoist ladles and will be coiled around spools and pulleys. Chain is not a player here.
Appreciate the help,
Re: Recommendation wanted for wire rope
Postby robert. » Wed May 17, 2023 10:30 pm
Try to roll your from bell wire.
Postby G3750 » Thu May 18, 2023 12:20 am
robert. wrote:Try to roll your from bell wire.
You're thinking of 20 gauge wire?
Postby ScaleCraft » Thu May 18, 2023 1:30 am
When I was just a wee lad, in my great-grandparent's garage, were all sorts of fishing poles (some about as big around as the grip on a baseball bat) and reels you had to hold with two hands.
I asked.
Marlins.
Off shore fishing.
The lines on one of the reels I imagine would look good for wire rope. Less than 1/8" OD.
That was almost 70 years ago, so I can't drive over and see where they got it.
And it won't stretch!
Postby G3750 » Thu May 18, 2023 10:46 am
Thank you Robert and Dave. I'm thinking the stuff used to string post-war crane cars might be the right stuff. Or maybe fishing line in the dimensions Dave mentioned.
Postby webenda » Thu May 18, 2023 3:34 pm
G3750 wrote:Hi All,
wire rope?
#3 picture hanging wire is perfect.
https://www.tractorsupply.com/tsc/produ ... RPEALw_wcB
Postby healey36 » Fri May 19, 2023 9:22 am
Picture-hanging wire looks good, but that stuff is a bear to bend and/or straighten/uncoil, and it tends to unravel, at least in my experience. Looks great, though, if you can get it to work for ya. Makes for nice-looking cable on a reel for your gondolas.
Postby G3750 » Fri May 19, 2023 10:07 am
healey36 wrote:Picture-hanging wire looks good, but that stuff is a bear to bend and/or straighten/uncoil, and it tends to unravel, at least in my experience. Looks great, though, if you can get it to work for ya. Makes for nice-looking cable on a reel for your gondolas.
Paul's correct. The application is a bridge crane carrying ladles for an open hearth steel mill. Unfortunately, real wire will not behave like the prototype, i.e. it's not carrying enough weight to straighten it out and defeat any kinks. So I must use string or cord or something that mimics wire but doesn't behave like it.
I have identified 2 sources. My local hobby shop thinks it has some of the postwar crane string (or whatever it's called) and I am checking that out today. Yesterday, I contacted a postwar parts supplier who says they have an equivalent and are sending me some, along with 2 crane/pulley assemblies.
Hopefully, one way or another, the problem is solved.
I will report back my findings.
Thanks to all who responded.
Postby healey36 » Fri May 19, 2023 11:41 am
Perhaps inappropriate for this application, but I've found some nice-looking fine chain in the jewelry-making department at the local craft store (Michael's). I've used that stuff for various purposes, including tie-downs on flat cars. Works pretty well, looks decent, but it's not real strong; it won't stand up to too much tightening.
Postby gregj410 » Fri May 19, 2023 7:37 pm
I was playing around with some basic things trying to get the look your after. The only unusual thing I used is this roll of string that was my dads. Must be every bit of 50 years old. :lol: They don’t make things the way they use to but I’d bet something similar is still around today.
I sprayed it down with aged gray paint, pulled it down with a rag to matt everything down. Wrapped it around a dowel. The piece you see hanging is by it’s own weight. Not bad for minimal resources and time.
Postby G3750 » Sat May 20, 2023 9:07 pm
Greg,
I remember stuff like that. Lasted forever, not like today. :roll:
I think it looks pretty good.
Postby sarge » Sun May 21, 2023 1:06 pm
Don't think it has anything to do with the good ol' days (real or embellished) as much as it looks like Greg's spool is intended for use on an industrial machine. Makes me think a canvas working or sailmaking business.
So, check out sailmakers and boat supply people. They have braided and laid small-stuff in a wide variety, so a good chance of finding something really good.
No-one has mentioned diameter yet, but 1" wire rope is nicely modelled with #1 or #2 suture silk. Anything bigger, see the above.
Postby webenda » Sun May 21, 2023 4:56 pm
Country Gray is an interesting choice of cable color.
In most steel mill pictures, everything looks black.
Postby webenda » Sun May 21, 2023 4:59 pm
A closer look:
Postby webenda » Sun May 21, 2023 5:14 pm
A look at a Lionel Crane car that was once in the North West Museum:
Its rope:
Size is 4/64 or 48x0.0625 = 3 inches in 1:48 scale.
