Small Hardware Source
86TA355SR
Postby 86TA355SR » Wed Feb 08, 2023 1:41 pm
What’s everyone’s source for small screws, washers, nuts, etc? Adding to that, drill bits (less than .020”)?
I find myself constantly in need of small hardware to fasten/build projects.
I’ve tried most common places (Fastenal/McMaster Carr/local hardware stores, MM, amazon, etc) nothing I need is small enough. Usually I can get down to 0-80 but nothing smaller.
For reference, need screws small enough for steam locomotive valve gear hangers, etc.
Thanks.
Aaron
Re: Small Hardware Source
Postby bob turner » Wed Feb 08, 2023 10:17 pm
00-90 is as small as you will find these days, and only in brass. Micro Fasteners has nuts machined to simulate prototype fasteners, also in brass, and steel 0-80 bolts. Walthers was the only reasonable source for 00-90.
That was not true in 1950 - Moody would sell steel hex heads down to triple zero -120 for cheap. I am using the last of my Coles Power Models steel hex heads - they may still have them, but I am not paying a buck each.
Best bet now is brass pins for valve gear. There is a basket place in Nantucket that sells them in quantity for cheap, and will drop them into the USMail if you ask nicely.
86TA355SR
Postby 86TA355SR » Thu Feb 09, 2023 12:21 am
Thanks
steamaheadstephen59
Postby steamaheadstephen59 » Thu Feb 09, 2023 4:41 am
I just order from China, hundreds at a time. I guess China may not be a favourite source. The truth is thats where most of our models come from. In Australia it just about impossible to find a local source at any quantity.
86TA355SR
Postby 86TA355SR » Thu Feb 09, 2023 11:45 am
Got a link?
Thanks
Postby up148 » Thu Feb 09, 2023 12:28 pm
I believe this company to be the best source of scale nuts, bolts, rivets, tools and so on. I know of no other like them. Scale Hardware carried more inventory, but this company (Model Motor Cars) bought them out several years back and I feel very fortunate they carry the line.
https://www.modelmotorcars.com/scalehardware/
86TA355SR
Postby 86TA355SR » Thu Feb 09, 2023 12:45 pm
up148 wrote:I believe this company to be the best source of scale nuts, bolts, rivets, tools and so on. I know of no other like them. Scale Hardware carried more inventory, but this company (Model Motor Cars) bought them out several years back and I feel very fortunate they carry the line.
Thank you. Hope all is well.
Aaron
Postby bob turner » Thu Feb 09, 2023 1:42 pm
D
This is a little messed up, format-wise. But it is a great deal if you need lots of carbon steel 00-90 screws. McMaster-Carr.
I now just use brass 00-90 to pin the Walschaerts and crosshead links. A scale nut looks good, and for testing (before Loctite or solder) I can easily fit everything together and check for operation and appearance.
rive
Lg. Threading Head
Dia. Head
Ht. Style Size Tensile
Strength, psi Pkg.
Qty. Pkg.
Black Corrosion-Resistant-Coated Steel
00-90
1/8" Fully Threaded 0.090" 0.036" Torx Plus IP2, T2 40,000 50 93701A001 $16.11
3/16" Fully Threaded 0.090" 0.036" Torx Plus IP2, T2 40,000 50 93701A003 17.32
1/4" Fully Threaded 0.090" 0.036" Torx Plus IP2, T2 40,000 50 93701A005 17.85
Postby up148 » Thu Feb 09, 2023 3:38 pm
Aaron
Crap Aaron, I forgot that was you....sorry. Don't get old. :lol:
All is well here and hope you're the same.
