I spent a couple days giving the Lionel 2034 recovered from the local antique mall a refurb. We've all done this, so nothing terribly exciting here. The tag said "$5 Doesn't Run", which seemed odd to me, as it looked to be complete. A quick disassembly found the E-unit filthy. A few squirts of electronic control cleaner/lubricant, along with a few toothpicks and Q-tips, and it was back in business. Additional lubricant using some clock oil and after a brief jerky spell, it was running smooth. I'll need to disassemble again at some point and give the face of the commutator a polish. I'm sure that's black, given the condition of the E-unit.
Cosmetically, it looked like it had been stored in a rock-tumbler for the last couple decades. Lots of paint off the edges along with a few large, rather prominent chips in the paintwork. Nothing broken, however, just a slightly bent marker lamp. I used a bit of a homebrew enamel to touch up the worst of worn away paint and filled the chips, then gave the whole casting an overspray of clear satin lacquer. I have found this serves well in blending the touch-ups with the original paint while retaining that semi-sheen they came with.
The 2034 was a down-market offering from Lionel in 1952, often grouped with the Scout line of locos. The 2034 is different, however, in that it doesn't feature the plastic motor and the two-position E-unit of the other Scouts, instead having a standard open-frame motor and a three-position E-unit (with the lever on the underside). In 1953, Lionel offered the 1130, same motor and E-unit, but with a plastic boiler, which then lead to the development of the 200-series Scouts we all know and love, lol.
I pimped it out a bit, adding a bell (the hole was there but Lionel left it off to save a few cents) and stuck a couple of those green jewels in the marker light positions. If I'd been really industrious, I would have drilled out the stanchion holes and added hand-rails along the side of the boiler, but that was too much like real work.
Finding a tender proved simple enough, although many of them have cracks or other problems. I found one on eBay for $15.00, offered $13.50, and it was on my doorstep in a few days. When it arrived, I discovered the truck side-frames were coated with waxy white crud, something I see frequently on Flyer link-couplers. I'm not sure what it is, likely some sort of oxidation of the plastic, or leaching chemical from the plastic formula, or possibly release agent from the molding process. It will scrape off, but the detail of the side-frames made that untenable. Whatever, getting it off is tough. Sarge made a number of suggestions, ranging from simple soap-and-water to mineral spirits. I've been having some good luck using white vinegar recently, so I decided to try that first. Using an old toothbrush and some vigorous scrubbing, I was able to remove about ninety-five percent of it. After letting it dry thoroughly, there's just a bit of it still there. I may try something a bit stronger to remove the last of it.
So anyway, here it is:
The 2034 turns seventy next year; this one seems ready for another seventy. My anal-retentive nature will likely have me running down its set consist, but we'll save that for after the holidays.
What else is cooking out there?
