Need a gear made
Need a gear made
Postby ScaleCraft » Thu Aug 19, 2021 1:58 pm
We finally got the failed original back for a sample.
Prefer steel, not aluminum as original.
MTH copy of pre-war Flyer Standard Gauge, 4695 4-4-2.
I have sample and photos. Has a hub for pressing onto shaft. Spur drive, like Lionel steam was.
large gear is approximately 1-7/16” diameter and has 50 teeth.
Any idea where to go?
Thanks
Re: Need a gear made
Postby bob turner » Thu Aug 19, 2021 7:42 pm
I know nothing about gear hobbing, but I would look for a hobbyist with a gear hobbing attachment. Or maybe buy one for a friend with a lathe.
Older train gears are standard parts, and for lots of $ Boston Gear will probably sell you one.
Raoul at NWSL was known to make a special gear now and then.
Postby bob turner » Thu Aug 19, 2021 9:32 pm
I found this tedious, but all the info is there. Three parts.
Google "gear hobbing"
https://m.youtube.com/watch?v=7WleHVtIc1c
Postby R.K. Maroon » Thu Aug 19, 2021 11:28 pm
There is a good chance that the gear is indeed standard, but it may be metric.
Dave: I can look into this but need the pitch diameter, which is approximately mid-tooth to mid-tooth. Also, it is important that the gear count is accurate, so double check that if it's not too tedious.
Postby ScaleCraft » Fri Aug 20, 2021 3:46 pm
working on it. Thanks
