Williams Passenger car coupler fix...
I recently obtained an older Williams NYC Passenger car and had a problem with de- coupling.I noticed that the rivited coupler had excessive up and down play so I used a nail set to tighten the rivet.Problem solved!
Re: Williams Passenger car coupler fix...
Good job!
You've solved for yourself what might have been 3 pages of never ending hand wringing over on OGR,
So true!I will find out later.
Some other forums seem to have members whose only only solution would be to return it to the dealer/seller because of this defect.
Now I can't repair electronic components but I can fix most loose couplers.
Yes I figured it was something simple...
