Absolutely HILARIOUS!
Postby ScaleCraft » Thu Dec 10, 2020 3:04 pm
https://www.ebay.com/itm/LIONEL-POST-WA ... 4408658979
They got the postwar bit sort of correct.
General Models NW-2 vertical motor base. Not sure what that angled bit screwed to one end is.
How they got the worm off the armature, I don't know. Useless without armature, worm, field, brushes.
Uh, Lionel?
Right......
Re: Absolutely HILARIOUS!
Postby rogruth » Thu Dec 10, 2020 11:14 pm
Strange. In my next life I may need a part like that.
But right now I don't know why I would. :roll: :roll: :wink: :wink: :)
Postby Rufus T. Firefly » Fri Dec 11, 2020 9:00 am
ScaleCraft wrote:Not sure what that angled bit screwed to one end is.
Tab for a broken off coupler that someone had added?
Useless
Just stop there.
Lionel?
For a rather large number of people, everything bigger than HO is Lionel regardless of what you might tell them or what the labels clearly state. Try telling this seller it's a drive block for a 2-rail NW2 and see what response you get.
Postby ScaleCraft » Fri Dec 11, 2020 3:23 pm
is this Stephen's stuff? Houston?
You'd think the seller (Baumann) would have a clue.
I suspect what the PO was trying to do was fit a can motor. As you can see, that didn't go very well.
Studiously avoided photos that show how badly bent the plate is.
That happens if you try to get the worm off. no real place to grab.
That NEVER happens on the bait, right?
Postby Rufus T. Firefly » Fri Dec 11, 2020 3:58 pm
ScaleCraft wrote:You'd think the seller (Baumann) would have a clue.
Why? Obviously doesn't.
Postby ScaleCraft » Fri Dec 11, 2020 4:51 pm
I do believe that is the mantra of most of these sellers.
Hands over their ears, shouting "I don't want to know!".
Maybe that's the way they can sleep at night without major pharmaceutical help.
Postby Rufus T. Firefly » Fri Dec 11, 2020 5:39 pm
Nah. They've convinced themselves that it's all Lionel and hence worth a fortune.
They sleep just fine happily snuggled up with their delusions....
Postby ScaleCraft » Fri Dec 11, 2020 7:20 pm
Good attitude:
"Dad is passed soooo no refunds no whining no returns look at photos"
