1130 Sunroof model
1130 Sunroof model
Postby ScaleCraft » Fri Nov 27, 2020 10:44 pm
https://www.ebay.com/itm/Lionel-1130-Mo ... 3851967631
No bids! Ten bucks! You can have a sunroof model 1130!
Re: 1130 Sunroof model
Postby Rufus T. Firefly » Sat Nov 28, 2020 10:05 am
What is everything but the boiler shell worth since it's claimed to run? Parts value is?
v8vega
Postby v8vega » Sat Nov 28, 2020 10:33 am
Shipping $10 tax $1 total $21.
Postby ScaleCraft » Sat Nov 28, 2020 12:35 pm
Rufus T. Firefly wrote:What is everything but the boiler shell worth since it's claimed to run? Parts value is?
That's where the problem lies.
Let's say you own a junkyard. You have a 24v generator off a 1944 Jeep. Is it worth something? Maybe.
All you have to do is find the "winner" who needs it.
Now, if someone needed to restore a plastic shell 1130, or even any other shell using the same motor block, then yes, there is a need.
The problem is, by the time a motor block is USUALLY in need of replacement, there is not much left of the shell....chipped, cracked, broken, corroded......and the quandary persists.
Postby Rufus T. Firefly » Sat Nov 28, 2020 1:32 pm
No, let's not say anything of the kind since I don't and I won't.
Postby rogruth » Sat Nov 28, 2020 5:52 pm
I like the one just under that for a Marx Lionel train.
2 Lionel cars with a Marx steam loco and NO tender.
