DCS is simple, if you're a NASA rocket scientist, that is.
https://ogrforum.ogaugerr.com/topic/wea ... 8285706612
chuck wrote:Re DCS. I don't believe it's "fixable" per se for large complex layouts without considerable rewiring to "smooth our" the communications issues. You are literally tying to build a data communications network on top of the layout power wiring. This isn't like DCC where the protocol is literally baked into the power, its just piggy backed on top of the 60/50 cycle power feed. Any noise on the line and the signal can get scrambled/lost. The "feature" of two way communication tends to make things worse as more bandwidth is wasted on retransmission. Easier to dump it and try something else.
I read somewhere -- probably CTT -- that the Lionel showroom was in the same building as a tv station and so Lionel's repair guy would take the Electronic set to the tv station and use their scope to keep it in tune.chuck wrote:The original Lionel Electronic set pretty much required a scope to adjust the tuning/frequency for each car. You COULD do it without a scope if you had the patience of a saint and had high quality/tolerance parts for when a component failed.
I was on the NMRA command control committee's listserve back in the 90s, when the standards and RPs were first being developed. The expertise on that committee was mind-blowing -- the committee had several EEs, the head of R&D at Volvo, a guy who managed technology development contracts for the military, etc. They were all active model railroaders with layouts they used to test stuff out on.chuck wrote:This isn't like DCC where the protocol is literally baked into the power, its just piggy backed on top of the 60/50 cycle power feed.
rogruth wrote:I have TMCC but after several years of using it I went back to conventional control. I had no problem with it but could not get it to work (even with some really expert help) for operating non TMCC locos. Probably my fault. My TMCC equipped locos worked fine but I just felt that for my small layout it was too much trouble.
I read all of the above posts about DCS and if I had gone through all of that I probably would have changed hobbies. DCS seems to be non stop irritations.
I am not an operator or scale modeler. I like to turn on my trains and watch them run.
in any scale, who run their trains conventionally.
chuck wrote:in any scale, who run their trains conventionally.
I wonder what would have happened if the LionChief/Bluetooth stuff had gotten out a little bit earlier. I was impressed by what you can do with the phone in terms of just running trains. It's not layout control, its just basic train control, F/N/R, whistle/bell/horn. Easy to set up, easy to control. No wiring at all! EZ/PZ.
Someday.I would like the one with remote couplers.
