Recommendation Wanted for Gluing Styrofoam
Postby G3750 » Sat Dec 14, 2019 12:12 pm
All:
Any recommendations for a strong glue for styrofoam? I've tried the Woodland Scenics Foam Tack Glue (ST-1444). It's less than impressive.
Re: Recommendation Wanted for Gluing Styrofoam
Postby sarge » Sat Dec 14, 2019 1:07 pm
Weldbond. Its about the best PVA you can get in the US.
Spread evenly with a piece of card and weights or clamps for an hour.
Postby chuck » Sat Dec 14, 2019 2:10 pm
Locktite power grab family. Non solvent based, you can get toothpaste sized tubes (3 oz and 6 oz). Ultimate even works on wet surfaces. Will not melt extruded polystyrene. Soap and water clean up.
I think the only things it won't glue are polypropylene and acetal resins. The later two require specialty superglues that include "debonder" pre-treatment to actually roughen up the plastic at the molecular level.
Postby G3750 » Sun Dec 15, 2019 11:15 am
Sarge, Chuck:
Many thanks!
Postby robert. » Sun Dec 15, 2019 9:13 pm
i used Elmer's wood glue. Home depot has it by the gallon. Then i ran a few drywall screws into it.
bluelinec4
Postby bluelinec4 » Thu Jan 16, 2020 11:27 pm
Liquid Nails foamboard adhesive works well
https://www.walmart.com/ip/Liquid-Nails ... gIab_D_BwE
Postby G3750 » Fri Jan 17, 2020 9:11 am
Thanks guys! Nice to hear from you, Ben. :)
Postby healey36 » Fri Jan 17, 2020 3:36 pm
Yes, I agree with Ben. I've used tubes of Liquid Nails in the past and it has worked well. It doesn't have a long shelf life, however, once you've opened the tube.
jwse30
Postby jwse30 » Fri Feb 07, 2020 7:40 pm
My attic access scuttle is in the garage. I built a new "door" for it by using 3 layers of 2" thick styrofoam glued together. Gravity holds it in place, as the top layer is larger than the scuttle. Liquid nails has held this contraption together for over a decade (probably jynxing the whole operation stating that), and gravity is trying to pull it apart, which is probably not the way you are intending on installing your foam if it is model railroad/ toy train related.
Liquid Nails makes numerous formulas, and I do not recall which one I used. I want to say it was the crafts recipe; whichever one it was it said on the tube that it was safe for foam. The original recipe does not say it is, or at least it didn't back then.
Hope this helps,
J White
