Bethgon or Bathgon
Bethgon or Bathgon
Postby E7 » Tue Nov 05, 2019 12:35 am
The big L has a rotary gondola and they call it a 'bathgon' or more accurately a bathtub gondola.
https://www.amazon.com/LIONEL-BATHTUB-G ... B06XXY752V
Re: Bethgon or Bathgon
Postby De Bruin » Tue Nov 05, 2019 10:36 am
mmm-hmm, and at $94 apiece putting a modestly realistic length unit train well within the budget of most 2-railers modeling the "modern image."
Wow, aside from the usual cast-on grabs and thick stirrups not bad :wink: .
Postby E7 » Tue Nov 05, 2019 10:54 am
I saw somewhere that Atlas was supposed to be doing them, but I couldn't bring up anything on them with my search.
I really have NO interest other than academic, but the talk over on NK of guys wanting 100 of the MMW brass ones at $600 a pop, made my wallet skip a beat. :shock:
Postby Chris Webster » Tue Nov 05, 2019 7:01 pm
De Bruin wrote:Wow, aside from the usual cast-on grabs and thick stirrups not bad :wink: .
The die-cast 100-ton 3-bay hoppers that Lionel did in 2006 are much nicer:
SKU: 6-11893 NORFOLK & WESTERN 3-BAY DIE-CAST COAL HOPPER 3-PACK
They have separate grabirons, spinning roller bearings and prototypical paint schemes.
The only negative is their weight -- I don't think anyone makes a coupler strong enough for a prototypical-length train of these cars. :)
Postby De Bruin » Tue Nov 05, 2019 11:11 pm
Yes those are nice, but IMO not modern enough to approximate one of those current (within the last 30 years) monster strings of Utility owned fleets that feed the Southern Co's grid and the C02 effluent stream, I'd love to see a good sized train in 1:48, ideally with distributed power tooling around someone's layout. CSX re-routes one of these through my neighborhood on it's way to Macon about once a month, they're humbling and sobering to behold. Maybe someone will spend 18 to 27K on the MMW versions and we'll see it, or you know, 2K to 3K on this Lionel version.
In terms of practicality, my experience in 1:48 is about forty cars is the usual threshold given a sufficient length for continous running, though I have seen analog industrial power supply powered trains on my old and absurdly large modular club layout in excess of 100 cars in the late eighties.
Back then it was a "show stopper."
Postby Chris Webster » Wed Nov 06, 2019 8:23 am
Rick Trinkle (the Trinkle Trains guy) was going to do just that by mass producing his own hoppers -- I met him 4 or 5 years ago at the big TCA show in Denver. I don't know if he actually pulled it off or not.
Postby E7 » Wed Nov 06, 2019 3:01 pm
The only place I recall seeing 100 car trains is the Chi-town Union Station layout. The old memory is fuzzy, but I think they were all hoppers of some sort, pulled by about four engines.
The problem I see with any of these looooooooong trains with identical cars is that they're booooooring.
Postby Rufus T. Firefly » Thu Nov 07, 2019 8:18 am
E7 wrote:The problem I see with any of these looooooooong trains with identical cars is that they're booooooring.
Yes. I suspect that those that can also afford to assemble trains of such size may doze off in the middle of their passing on the layout anyway.
EdJakl
Postby EdJakl » Thu Nov 07, 2019 7:07 pm
Here's a string, starting at the 4:24 minute mark
https://www.youtube.com/watch?v=rQ6HrcMEP54
These were NOT $600 per car. They were vacuumed formed cars made by Barney Stemple (sp?)
Postby Chris Webster » Sun Feb 02, 2020 6:23 pm
Not bethgons, but some really neat footage of a train of loaded Norfolk Southern "Top Gons" on an HO layout:
https://youtu.be/1T7lR73NyVs?t=341
Postby ScaleCraft » Mon Feb 03, 2020 2:50 pm
I remember....20-25 years ago, in 2-rail, somebody produced a brass, painted (?) two bay hopper. Everyone was ga-ga over it, and at the time they were a couple hundred each.
So, I finished up a string of three SC cast two-bays, countersunk screw assembled instead of drive pings, painted and NP lettered. Took them to the gathering at Garbersons, set them on the display table inside the front door, and everyone went nuts. Until I picked one up and showed them they were at least 50 year old SC hoppers.
Some of the Lionel stuff.....chisel off the grabs and steps, fill, smooth, install scale grabs and steps, paint and letter, and sometimes you get away with it....
Postby E7 » Tue Feb 04, 2020 2:27 am
ScaleCraft wrote:I remember....20-25 years ago, in 2-rail, somebody produced a brass, painted (?) two bay hopper. Everyone was ga-ga over it, and at the time they were a couple hundred each.
No shame in that. It all depends on what YOU like and are willing to accept. The de vil is in the details, meaning how much detail do you want/need.
Postby ScaleCraft » Tue Feb 04, 2020 3:04 pm
and first glance, nobody knew. Key issue.
Postby E7 » Tue Feb 04, 2020 3:27 pm
ScaleCraft wrote:and first glance, nobody knew. Key issue.
The dreaded 3 foot rule, maybe!
Postby J. S. Bach » Tue Feb 04, 2020 6:00 pm
E7 wrote:No shame in that. It all depends on what YOU like and are willing to accept. The de vil is in the details, meaning how much detail do you want/need.
I am perfectly happy with the Weaver, SC, etc level of detail. Less stuff to fall/break off; like with Intermountain's products.
