Smoky Mountain 70-Ton Flat Car
Just about finished my Smoky Mountain Model Works AAR 53' 6", 70-Ton Flat Car. I used a wood deck in place of the supplied urethane deck. Being what I call a "runner" on the layout I used Kadee couplers for switching. Decals from Protocraft.
Working on the loads now.
- PM16832_1.jpg (302.54 KiB) Viewed 6260 times
- PM16832_2.jpg (274.73 KiB) Viewed 6260 times
Regards,
Dan
Dan
Re: Smoky Mountain 70-Ton Flat Car
Dan, very nice!
Beautiful!
Question if you would, do you apply decals to gloss paint and then Dullcote it?
2railjon wrote:Beautiful!
Mostly. I only use Scalecoat on rolling stock which gives me the great glass finish ready for decals. I stopped using Dullcote years ago after Matthew Forsyth suggested Krylon 1311 matte spray. I really like it right out of the rattle can. Decals and I have a love hate relationship but this turned out very well.
Regards,
Dan
Dan
RDSRR wrote:I stopped using Dullcote years ago after Matthew Forsyth suggested Krylon 1311 matte spray. I really like it right out of the rattle can.
Similarly, I also discontinued using Dullcote years ago and switched to Rustoleum matte spray, and also right out of the rattle can.
Nice finish work on the deck, Dan. Any tips there to share on how you approached that?
Nice decals.
I have been having trouble with Krylon and Rustoleum - mostly nozzle and propellant problems. I have found that "Dupli-Color, while twice as expensive, puts out a nice even spray pattern and allows me to use all the paint even after a couple years between spray jobs.
Krylon was really, really good right up into the 1990s, but now not worth the effort. Rustoleum made it to about 2010 before dropping the ball.
They hire the same kind of people that Hotmail hires: "Let's keep changing things until nobody knows what is going on!"
R.K. Maroon wrote:Nice finish work on the deck, Dan. Any tips there to share on how you approached that?
I cut the wood to length using the urethane deck as a guide around the T section. I found some great "recipes" for staining wood. Here is a link: https://www.rustystumps.com/RSSMDownloa ... ipwood.pdf
I used the dull gray version. Once applied to the car it's all Pan Pastels simply worked in with a stiff brush till I thought it looked right.
Regards,
Dan
Dan
Thank you, Dan -- Great link. The articles are very informative (be sure to get part 2 by going to the rusty stumps home page). I was also unaware of the O-scale detail parts they sell. Lots of neat detail items.
- rex desilets
Good job!
Since the car is resin, do you intend to run it empty? If not, have you added bracing underneath?
rex desilets wrote:Good job!
The kit includes a weight that fits into the sill. However, I am working on a tractor load. I build up all the chocks based on an old AAR spec. Next is the chain... The tractors are 1947 models and since I model 1947 well it works!
Regards,
Dan
Dan
1947 was a good year. Once we get past about 1965 I am no longer interested - in trains, cars (except for my wife's 635csi) and airplanes. Oh, I guess I did like the Airbus, but you gotta admit it looks like a big engined 737.
Chain came from Clover House. Note that is not round like some. A bit heavy bit it will work.
Regards,
Dan
Dan
OK, I know that most farm equipment was strapped and not chained but... what are you going to do
Regards,
Dan
Dan
RDSRR wrote:......... was strapped and not chained but... what are you going to do
O tempora! o mores! Ok, it's not really a problem these days as long as it's between consenting adults,
Users browsing this forum: up148 and 62 guests
