Varney A-N 4-6-0 gearing
Postby ScaleCraft » Sat Nov 10, 2018 12:10 am
So.
I have parts now to fix this old 4-6-0.
The one I have has fine teeth gears, worm and axle.
The parts loco has coarser teeth on both.
No idea on vintage, but guess finer is older (as Varney in Half-0 did that..coarser in later years).
Any choices on which it better?
Re: Varney A-N 4-6-0 gearing
Postby J. S. Bach » Sat Nov 10, 2018 10:55 am
Are both runable? At least enough to see which has better low-speed operation. Just a thought.
Postby ScaleCraft » Sat Nov 10, 2018 12:15 pm
no. Neither, yet, but looking for opines prior to final assembly.
I will count off the ratio first.
Postby ScaleCraft » Sat Nov 10, 2018 3:06 pm
hard to do, counted 1/2 driver turn and doubled it. Looks like 18:1 for coarse, 42:1 for fine.
Rough numbers usually are 15:1 diesel, 30:1 steam. At least in the larger stuff I do.
Think I'll keep away from land speed records and do the 40-ish:1.
Postby ScaleCraft » Sat Nov 10, 2018 7:08 pm
okay...I have two chassis, Two gear/motor bridges, one motor (so far).
NO instructions, none of the bridges were mounted, no screws.
Fits intuitively up to a point. Rear mount, found a long screw..okay. Front hole does not line up with bottom plate...I can fix that. But the shoe on the front of the bridge, with rear mount flush to frame, and bridge extended fully in slots, is oh, at least 1/4" away from the bottom plate.
This can't be right. No ability to keep side rocking at the front of the bridge out.
Is there a spacer block that fits in there, or a spring, or what?
Postby bob turner » Sat Nov 10, 2018 7:41 pm
I think you are missing a spacer. They are usually round, and some were basically rivets. Look for holes in the frame roughly where a spacer would support that housing.
Postby ScaleCraft » Sat Nov 10, 2018 7:49 pm
got the hole for the screw to fit into the front "shoe" of the bracket, but no other holes to hold a spacer.
John Webster
Postby John Webster » Sun Nov 11, 2018 2:41 am
The drawing I have (1564-A dated 2-14-45) shows the "shoe" mounted with the large flat surface above the drive shaft. The end of the double bend bolts to the bottom cover plate ahead of the center driver. There may be a spacer between the cover plate and the shoe. The other end bolts to the rear face of an overbent L bracket that sits across the top of the frame between the rear drivers and is held by a screw through the bottom cover plate. The motor is held in place by the two screws that hold the shoe to the L bracket.
Postby ScaleCraft » Sun Nov 11, 2018 12:03 pm
John Webster wrote:The drawing I have (1564-A dated 2-14-45) shows the "shoe" mounted with the large flat surface above the drive shaft. The end of the double bend bolts to the bottom cover plate ahead of the center driver. There may be a spacer between the cover plate and the shoe. The other end bolts to the rear face of an overbent L bracket that sits across the top of the frame between the rear drivers and is held by a screw through the bottom cover plate. The motor is held in place by the two screws that hold the shoe to the L bracket.
Got all that except " There may be a spacer between the cover plate and the shoe."
If you were able to get the angle right to bolt the shoe of the gear bridge to the bottom cover, the motor would be in the air so far you would have to use #1 gauge clearances. So, there SHOULD be a spacer....one would think....
Postby R.K. Maroon » Sun Nov 11, 2018 3:32 pm
I have only put one of these together, and I didn't have a drawing. Here is a photo for reference:
My memory is that the bracket at the motor end screws flush and firm to the the chassis. In this position the worm does not adequately engage the worm gear. The bracket at the worm end does not screw flush and firm. The screw into this bracket from the chassis is tightened to pull the worm into proper engagement with the worm gear. I also recall that the machine screw involved is a #5 -- a bit of a challenge to find if you don't have one.
Take all this with a lot of skepticism. For one, my memory is faulty. Also, I believe this model is an original Varney (or maybe a very early GMC), and it may be that the design changed over the years. Of course, it could also be that there was supposed to be a spacer and it was simply missing. But I will say this model runs like a top -- surprisingly smooth and quiet for a seventy-year-old model.
JIm
Postby ScaleCraft » Sun Nov 11, 2018 4:50 pm
And there is no coiled spring between bottom cover and end of gear box bridge to ensure tension on screw so it doesn't walk?
With the slotted parts at the motor end of the bridge, would have thought tight in front, tight on back mount, move the bridge up and down for mesh.
Postby R.K. Maroon » Sun Nov 11, 2018 5:26 pm
My memory is that the action of the front screw bends the bracket to bring the worm into correct engagement. This bending acts as a spring, which tends to lock the screw. I agree is sounds a bit "not kosher", but that is what I remember. And again, it may be that mine worked this way and later ones don't. Or it may be that I put it together incorrectly, and it's just luck that it runs so well and perhaps just a matter of time before it chews itself up. On the other hand, we know that 1946 was still the era of great experimentation for locomotive drives. If my model was designed to be assembled as I did, it does have the advantage of having an adjustment and thus eliminating the cost of having a precision fit among all the parts involved.
Postby ScaleCraft » Sun Nov 11, 2018 6:30 pm
okay. The brass bridge works as a spring. Explains why the bearing at the front is a loose fit!
Wonder what the process is for setting the slot adjustment at the motor end, then....
Postby ScaleCraft » Mon Nov 12, 2018 12:29 am
The frames appear to be factory assembles and peened. But the bottom cover. Are those holes fr the retaining screws and motor/gearbox bridge to be drilled by the new owner?
None of them are right...run a straightedge along them, they are all over the place. Rattail files fixed it, but boy.
I had noticed when I tried to find all the bits and rebuild this a number of years ago, that the back side of the front of the bride at the shoe is either way too close to the worm gear or hitting it.
I relieved it..neatly...and now I can see light past the two when assembled.
Power applied, drivers turn.
I cleaned up parts and painted valve hanger and bulkheads, cylinders, pilot deck, beam, and catcher.
The one I am working on has a frame that is 1/2" longer than the other. Te rear cab mount and drawbar point is extended back with gusset plates. Now I need to check the existing boiler to see if he'd done something with the cab. Most likely.
Postby ScaleCraft » Thu Nov 15, 2018 9:09 pm
Coarse gearing (high speed) on spare unit.
Fine gearing as installed.
