any ideas?
any ideas?
Postby ScaleCraft » Sat Nov 03, 2018 10:25 pm
In a big box of stuff cleaned out of a railroad we took apart some time ago.
Sorting, storing, and found this.
Guy flew (United?) and did 0 stuff, and it's in a box of 0 shi....well..
About 3.5" long, 1.25" wide, 1" tall.
Re: any ideas?
Postby ScaleCraft » Sun Nov 04, 2018 1:36 am
I keep thinkin' "reverb". Moving the lever lengthens and shortens the visible spring in the port.......and I know spring reverbs, but this ain't one of those.
Re: any ideas?
Postby Dennis Holler » Sun Nov 04, 2018 6:21 pm
I seem to remember seeing advertisements for a "B K Enterprises" or something similar in old Model Railroaders for the 1940's or so.
Re: any ideas?
Postby ScaleCraft » Sun Nov 04, 2018 8:57 pm
I thought BK made switches and crossovers?
Re: any ideas?
Postby ScaleCraft » Tue Nov 06, 2018 11:31 pm
Finally just took it apart. Hard to do. Machines cast bakelite, with metal threaded inserts pressed in...and decades of heat and vibration caused locked screws and loose inserts.
Heavy duty, adjustable flasher, or timer.
The adjustment arm set the speed.
Two big contacts with middle arm, so a NO and NC position.
Most likely he used it for grade crossing lights.
Re: any ideas?
Postby rogruth » Thu Nov 08, 2018 2:16 pm
The same type of thing is a lot smaller today but probably wont last as long. Cool.
