Weekend Photos - 9/14/18
christopher2035
Postby christopher2035 » Fri Sep 14, 2018 9:42 am
Happy Friday!
working on more wiring & running some postwar classics this week!
NS Dash-9 9694 leads eastbound 20Q as it ducks under the classic PRR signals in Summerhill, PA.
N&W 611 puts on a show as she rolls on the grounds of the NCTM in Spencer, NC
UP SD70ACe 8371 hustles 22A through Wabun, VA in the early morning hours of 10/27/17
NS SD70ACU 7292 (ex UP SD90MAC 8064/UP 3519) leads 83J through Welch, WV on the Pokey at dusk
Christopher
Re: Weekend Photos - 9/14/18
Postby healey36 » Fri Sep 14, 2018 12:29 pm
Just brilliant:
Did you wire the tunnel so that the light shines through the windows in the small houses?
What are you using for roadbed, Christopher? Looks like some sort of rubberized material, but not the kind that seats the cross-ties...
Found this little Flyer 3008 on eBay recently:
Needed it for a small set I've been trying to cobble together. For whatever reason, it's been tough to find one retaining most of its paint.
Paul
christopher2035
Postby christopher2035 » Tue Sep 18, 2018 11:15 am
I'm using the woodland scenics roadbed. IDK if I'm going to use it on the inside track - it doesn't really give that much of a pronounced slope for the ballast & is kind of $$. The inside walls of the tunnel are solid so the light doesn't shine through. I had to move the tunnel over the weekend as I extended the 2nd main & I feel it kind of gets lost where it is now, but didn't really have much of a choice.
Christopher
