International market going up ?
Postby Carey Williams » Mon Aug 20, 2018 2:33 pm
There seems to be new blood going after International pieces these days ..... IMP certainly opened the path for imported product from Japan .....
perhaps there is a revival going on ?
https://www.ebay.com/itm/O-Scale-Sheet- ... 3102554024
https://www.ebay.com/itm/O-Scale-Sheet- ... 3108629238
https://www.ebay.com/itm/VINTAGE-ELECTR ... 2688580220
Re: International market going up ?
Postby bob turner » Mon Aug 20, 2018 7:14 pm
What fun! At a distance, these look ok. It is only when you discover how flimsoid . . .
Postby ScaleCraft » Mon Aug 20, 2018 9:31 pm
Flimsoid? Yes.
Field wound. Skinny frames.
I used to pick these up from time to time in lots, gave them all to RK "Bob" Hall for his use. I had no time for them.
Postby Rufus T. Firefly » Tue Aug 21, 2018 8:57 am
The boxcab is mildly interesting as it's not the usual B-B body on it - earlier variant?
However, not interesting enough to pursue at any cost.
Postby Carey Williams » Tue Aug 21, 2018 12:01 pm
Come on Rufus take the plunge ....once you go vintage you never go back ..
box cab is one of the earlier pieces offered 17/64ths scale ( in the loose sense of the word)
I believe the box cab hit the scene in 1948
BB electric plans.jpg (391.29 KiB) Viewed 4051 times
My IMP favorites are the Challenger and Swallow which are a cut or two /3 ? above the normal IMP line ...
Most the IMP line was in the $20-40 range .....Challenger $225 special order only (1951-4) , placed in the price range of Max Gray when he hit the scene a few years later...
IMP filled a niche for cheap engines ...and offered them two or three rail !...
"No Solder No Flash"....."Less Bother Less Cash"...
Swallow Hudson 2018.jpg (250.75 KiB) Viewed 4051 times
Postby Rufus T. Firefly » Tue Aug 21, 2018 12:21 pm
Carey Williams wrote:Come on Rufus take the plunge ....once you go vintage you never go back ..
The IMP ED144 was visited in my column in OST quite a while ago and will get revisited at some future point in time. I've had 6 or more of these about the shop and still have 2-3. I have however sold off all of the rest of those and other various models -- only so much room & time.
The steeple cab is another IMP model that I will be visiting in the future.
Postby Carey Williams » Tue Aug 21, 2018 12:34 pm
Hello world ...IMP's are hitting the scene ..here is a rather optimist seller ?
https://www.ebay.com/itm/Brass-New-Have ... ition=3000
