Accurate O Drive
Accurate O Drive
Postby up148 » Thu Apr 19, 2018 11:01 am
Just curious, I've been perusing my OSN collection and see several ads back in the early 2000's when Jerry Snow was offering these drives. Pretty expensive (at least for me), but the alternatives at the time were fairly limited. Does anyone have any experience with them? How did they run, were they problematic or bullet proof, etc.?
BH
Re: Accurate O Drive
Postby Jay Criswell » Thu Apr 19, 2018 11:26 am
Butch,
Let's see, yes, fine, not for the most part, nothing is bullet proof...I can destroy anything.
As to the current status of Jerry's drives? Not sure. He did contact me, quite a few years ago, about buying some of the helical gears but it never went much beyond that. Basically, my drive is a continuation of his with enhancements (hyperbole much!) made along the way. I still have 3 or 4 dozen of the Pittman gear head motors.
How I got into this whole replacement drive fiasco is a story for another day.
Postby sarge » Thu Apr 19, 2018 1:08 pm
Jerry did a drive for me in a GE/IR boxcab back on '04 or so. I reviewed it in OST #19, so you can see photos if you want. It wasn't complicated but it was quite nice and I ran it pretty hard for years.
Big Pittman, flywheel, ball bearings, cogbelt. Nicely engineered as I used it and up to the task. It worked for me.
Postby up148 » Thu Apr 19, 2018 2:05 pm
NOw that you mention it Sarge, I remember reading that article. I'll start perusing my OST mags in a few days and reread your article. But, yours if the only one I ever heard about and just wondered if his conversions ever really gained a following. He was a pretty creative guy.
Jay, yes, your drive and his are similar (belt drives, etc.), but yours is more complete (opinion).
BH
Postby sarge » Fri Apr 20, 2018 8:26 am
Butch
I really don't know if he did many of them. It was well thought out and I am a fan of elegant simplicity, so it had all the right stuff and nothing more. It was a solid utilitarian drive with no frills on the one hand and no bad habits on the other. I ran it both in conventional control and DCC, and it never gave a moment's doubt it was not up to the task.
Postby Robert » Fri Apr 20, 2018 8:36 am
sarge wrote:Jerry did a drive for me in a GE/IR boxcab back on '04 or so. I reviewed it in OST #19, so you can see photos if you want. It wasn't complicated but it was quite nice and I ran it pretty hard for years. Big Pittman, flywheel, ball bearings, cogbelt. Nicely engineered as I used it and up to the task. It worked for me.
I've been curious about Jerry's drive as well. It looks like the viewable back issue archive is gone...thus no OST 19 available. Any other way of seeing what the drive looked like Sarge?
Thanks
Postby Jay Criswell » Fri Apr 20, 2018 10:25 am
Butch,
There's so much more to the story but I don't think it's really fair for me to expound on it unless Jerry was involved to complete the tale. I will say, from what Jerry & Raoul (NWSL) told me, it was a collaboration between the two of them.
My drives started off exactly like Jerry's but the intent wasn't to copy his or to steal his ideas. I started doing it because Norm wanted new drives for some of his models and we couldn't get the required parts.
Back to what I'm doing, I see it as a natural progression of improving and expanding capabilities. As an example, the tower on Jerry's drive didn't allow for ratio changes or adjustment of the belt tension. I thought that was important so we created a new tower/motor mount. Another was the fact that Jerry's was strictly a tank drive set up. I personally, don't have an issue with tank drives but many do so we created the towers that attach the the truck gearboxes. Another example would be using the Faulhaber gear head motors. I didn't do it because they are a better design, run quieter, or draw less amps. I did it because the Pittman gear head won't fit in the plastic shells of the most common hood unit models.
Back to the natural progression. I'm sure if Jerry had of continued with his drives he would have done many of the same things I've done but probably better. Don't forget, Jerry is a very talented modeler and I wouldn't doubt he could do anything he set his mind to. I consider him a friend.
Way more than I intended to write.
Postby Jay Criswell » Sun Apr 22, 2018 5:25 pm
Just posted this on the Right-O'-Way FB page. Things have been kinda slow with Right-O'-Way, no, I'm not complaining. It gives me a chance to get back to what I really enjoy...building new drives. I'm only about a year and a half behind. Gearboxes ready, input shafts, ditto, O Scale axles w/wheels are ready. Only have to mount the gears, thrust washers, ball bearings, and wheels for the P:48 version and I can start assembly. Whoo Hoo! Fun times are a'comin'.
GreggL
Postby GreggL » Sun Apr 22, 2018 5:32 pm
Jay Criswell wrote:I'm only about a year and a half behind. Gearboxes ready, input shafts, ditto, O Scale axles w/wheels are ready. Only have to mount the gears, thrust washers, ball bearings, and wheels for the P:48 version and I can start assembly. Whoo Hoo! Fun times are a'comin'.
Am I familiar with this project? :wink:
Postby Jay Criswell » Sun Apr 22, 2018 5:34 pm
The one you're familiar with is further along.
Postby Rufus T. Firefly » Sun Apr 22, 2018 6:00 pm
Robert wrote:I've been curious about Jerry's drive as well. It looks like the viewable back issue archive is gone...thus no OST 19 available. Any other way of seeing what the drive looked like Sarge?
Yes & no. It's there but not visibly active thanks to our new web master, :roll: :roll: :roll: :roll: :roll:
If you need a copy, let me know.
Postby Jay Criswell » Sun Apr 22, 2018 6:20 pm
Rufus,
I would like to get a copy also. Please let me know what I need to do.
Postby Rufus T. Firefly » Sun Apr 22, 2018 6:24 pm
Jay Criswell wrote:Rufus,
Which e-mail address do I use? It's just barely under 15 megs in size
Postby Jay Criswell » Sun Apr 22, 2018 6:45 pm
RFT,
jay@right-o-way.us will work fine...I hope.
Postby Jay Criswell » Sun Apr 22, 2018 7:05 pm
Thanks Martin,
Came through just fine. Now I have something to read tonight.
The thing that struck me most. It wasn't that long ago yet it's a virtual trip down Memory Lane.
