https://www.ebay.com/itm/Ajin-Brass-UP- ... Sw6o1alxPJ
Fix the drive and you have something. One of OMI's better efforts and nice paint. If I did UP I would seriously consider this one!
My Ebay option
herronpeter
Re: My Ebay option
I'm guessing it has the dreaded "tank drive". Perhaps why the seller left out a bottom shot when every other angle is shown.
Peter
Peter
Re: My Ebay option
Agree this likely has that tank-drive with with delrin tube link between the Sagami and domino tower which is laughably bad.
I bought one at San Antonio National in '88 and (to repeat an earlier post sorry) after eventually getting the drive connection straightened out with a universal (three motors later) I discovered that both the truck side frames had taken a bow from extended operation on oval layout(s) and that the wheels had floated inward on their axles as well. My friend Joe Grillo rebuilt it while visiting NWSL two years ago.
On the good side; the model and detail excellent. Originally an un-painted factory "generic" version it came with a ton of optional parts to make a lot of different road variants as well an E9, goodies like a nose door with headlight, extra grabs, a separate roof plate with a Dynamic Brake fan, diaphragm striker plate, bracket and leafs, four different horn sets, a pair of those square riser plates with the curved sides the UP versions had over the exhaust(?) The car body had no port holes either, which naturally were the first details I installed (NYC)
I'd sure do it differently now...
Re: My Ebay option
herronpeter wrote:I'm guessing it has the dreaded "tank drive". Perhaps why the seller left out a bottom shot when every other angle is shown.
A black drive shaft appears to be visible in the sixth photo, directly under the "O" and "N".
Re: My Ebay option
"The dreaded tank drive". If you can't see it, is it still dreaded?
Re: My Ebay option
Ancient history, since they apparently fixed it - I refused to let folks bring Overland stuff in my house, for fear it would disassemble itself and eat its own you joints.
I think semi-recent stuff is better; I have recent PAs that seem ok. That early turbine was a gorgeous disaster!
