The PECKING order
The PECKING order
Postby E7 » Sat Jan 27, 2018 4:06 pm
What "WE" like is, of course, what we like. It has always seemed to me that the ALPHA model :lol: :lol: was the Locomotive, and all else secondary. But................I notice among many (Here and There), an almost fanatical devotion to the accuracy of their passenger cars above ALL else. Are the windows the right place and correct in number? Is the fluting the correct shape and of accurate number of flutes/flouts egad!!? Interiors.......I'll be the first to confess that I don't/never did give a crap if my passenger stuff had interiors as they are mostly hidden......and to show I am equal opportunity of sorts, I almost giggle when there is talk of installing a "prime mover" inside some of the latest locos (all my stuff already has prime movers, which are called MOTORS! :mrgreen: ) Where does the modeling end and the p*ssing contest begin?
Your Thoughts?
Re: The PECKING order
Postby ScaleCraft » Sat Jan 27, 2018 5:27 pm
I have some passenger cars with interiors...but I never did them. They came that way. The one club car is neat, vases on the tables.
Surprisingly, the number of folks that HAVE to have full, exact underbody detail..and pay a lot to have such (and then ruin it by installing KD's) that you will only ONLY see in normal operation if you do something wrong.....like have a mondo wreck and dump all those $450 hoppers on their sides.
Postby De Bruin » Sat Jan 27, 2018 5:39 pm
I do spend more time and tend to try be more rigorous with regards to fidelity to the prototype on Passenger Cars.(Diesels too) But as window plans are difficult to reproduce I do wind up cheating and use other plans as stand ins. I'm certainly not in the same zip code with regard to either Terry's PRR or NP cars or certainly Bill's dead nuts replicas of MP&T&P ACF products. And then there's Dan Pantera, who does amazing work as well.
I have evolved to using liners, window treatments like shades, putting in enough interior to keep the view from looking empty or see through when it should not, and I use the same approach with under bodies. But I'm no fine scale modeler that's for sure.
Since I tend to model based on my photos of a specific train I generally try and get a reasonable facsimile if I can't nail the plan. Getting the right parts can be a bother too, I don't like wasting money on an entire BC-M kit just to get the car end plates for the Chester project I'm currently building for example so I may fabricate them and they likely won't look that good either. Ditto scoring ICC car ends to fit the Kasiner, CSC extrusions.
But if the result looks like the photo in the end, especially employing Jim's thirty mph with a martini in hand rule, then I'm good.
Postby Rufus T. Firefly » Sat Jan 27, 2018 6:13 pm
De Bruin wrote: I have evolved to using liners, window treatments like shades, putting in enough interior to keep the view from looking empty or see through when it should not, and I use the same approach with under bodies. But I'm no fine scale modeler that's for sure.
I perform similar exercises for the same reason. Limit the "nakedness" of empty interiors and absent underbodies that detract from the appearance of the model. Whether it's accurate is another issue - I'm not a precise prototype model. I rarely build prototype models as I find that a boring pursuit.
Postby Seaboard Air Line Fan » Sat Jan 27, 2018 7:13 pm
I do like the windows to be in the correct location, I can put interiors in but if they come with it that's great.
Passenger car trucks are starting to get my attention, but I don't know the right ones from the wrong ones :shock:
A lot of things a modeler can easily fix, but window placement ain't one of them.
rex desilets
Postby rex desilets » Sat Jan 27, 2018 8:06 pm
Well, in this modern day and age, you can obtain car sides with the proper window configuration
https://unionstationproducts.com/?target=main
..unless you're a metal passenger car model snob. :lol:
Postby bob turner » Sat Jan 27, 2018 8:30 pm
I resemble that remark. But I have an end mill, and can put windows anywhere I want, which may or may not be absolutely correct. And I like interiors, so long as I do not have to do the work.
But as I was putting air and train lines on a pair of Berks, I reflected on the difference between me and, say, Ed Spanknoble and the boys: once the visible parts look ok, I just terminate them under air tanks or reversers. I want my models to look ok, not to be perfect.
I am with Bob - my passenger cars must have reasonably good trucks. I would rather have sand cast trucks of the correct proportions than fully sprung but incorrectly proportioned trucks. I bet 2-rail Jon comes around right after he converts all those shortie Weaver trucks.
Postby Seaboard Air Line Fan » Sat Jan 27, 2018 8:40 pm
Been there, done that.
I got a USP styrene wrapper for a Pullman 10-6 sleeper and adhered it to an OK Engines aluminum shell, with cutouts in the area where the window groups were.
Didn’t care for the USP body core, never could successfully attach the wrapper to the core without it showing some warping.
I thought I had posted photos here but I can’t find them on my computer.
Postby Jay Criswell » Sat Jan 27, 2018 10:00 pm
Pete,
Like these?
2018-01-27 003.JPG (1.32 MiB) Viewed 6069 times
2018-01-27 002.JPG (1.54 MiB) Viewed 6069 times
2018-01-27 001.JPG (1.71 MiB) Viewed 6069 times
Postby De Bruin » Sat Jan 27, 2018 10:26 pm
Why yes, Jay, like those, apparently there's a breeding program extant. I assume these are remnants from the old BC-M line from Lou Cross? Let me know if some may be purchased, I would appreciate it greatly.
Thanks
rex desilets
Postby rex desilets » Sat Jan 27, 2018 10:34 pm
Seaboard Air Line Fan wrote:<snip>
<snip>
Distressing information. What thickness are the USP car sides? Could one adhere a styrene sheet stiffener to cure the problem?
Postby Jay Criswell » Sat Jan 27, 2018 10:38 pm
Pete,
Remnants? Yeah, I guess. We have all the tooling and, just like the sides and most of the other detail parts, we make them out of brass now. No use for plastic cars sides. Largest customer is Dan Pantera.
How many do you want?
rex desilets
Postby rex desilets » Sat Jan 27, 2018 10:57 pm
De Bruin said:
"Since I tend to model based on my photos of a specific train I generally try and get a reasonable facsimile if I can't nail the plan. Getting the right parts can be a bother too, I don't like wasting money on an entire BC-M kit just to get the car end plates for the Chester project I'm currently building for example so I may fabricate them and they likely won't look that good either. Ditto scoring ICC car ends to fit the Kasiner, CSC extrusions."
The ICC kits show up on ebay from time to time and I've scored several at pretty good prices.
I'd think you could use the ends as masters for molds in which to cast new ends in resin.
For me, the kits (where the window configuration is not of interest) will serve as core kits for the Union Station sides (suitably stiffened, I suppose...)
rex desilets
Postby rex desilets » Sat Jan 27, 2018 11:09 pm
Bob Turner...my snark about metal model snobs was a gentle yank of your chain, knowing your oft-expressed disdain for plastic models.
I suppose if I had your machine tools and the skill to use them, I'd be a metal snob, too.
Anyway, the late, great Bill Clouser wrote in a long-ago issue of Model Railroader that the material used for a model was not as important as proper preparation, and so forth. He used Strathmore board a lot, and once turned out an EMD E-unit with the nose shaped in balsa. :) 8) :wink:
Postby bob turner » Sat Jan 27, 2018 11:13 pm
I ever really thought about it. My Kasiner ends are usually aluminum plate, screwed to a wood floor and ceiling with FH wood screws. The diaphragm covers the screw heads. My Mac Shop and Speer extrusions use those nice one-piece brass ends made from Kemtron patterns.
