Live steam O scale Mountain
- John Webster
Re: Live steam O scale Mountain
WOW! It looks like someone took a conventional brass locomotive and converted it to a live steam model. I am sure the detailed cosmetic boiler is hiding a pressure vessel inside of it. Actual steam valves can be seen down inside the loco's frame. Not my cup of tea but a very interesting concept. This harkens back to the 1930s when such things were being considered and built in O scale.
Joe
Joe
Reminds me a little of BillHoffman's air engines.
Nicely done. The seller is confusing hourly rates and value. If you wanted to get a good machinist to build one of these for you it ma well run over six grand, but drive it around the block . . .
stephen neill
Thanks John for bringing this to our attention. Even though the seller knows it is O scale, they did not list it in the O scale section, so a lot of us that look at Ebay would not have come across it.
I tried to determine if it was a 2 rail or 3 rail locomotive; the relevant point being whether the wheels are insulated; thus whether it could be run on 2 rail track without causing a short. If anyone can tell, I'd be interested. The seller seems to be Lionel oriented and thus may not have given this a thought.
I am not interested in buying it, just curious. Also, I have a Little Engines O scale live steam kit that I bought years ago that I would sell if someone is interested.
Steve
Steve
I am familiar with Bill Hoffman's air powered steam locomotive models and had the fun of running them at the BSME many times during our annual Christmas season shows. I was told that the boiler on his UP 4-8-8-4 was made from part of a Ford tailpipe. Bill scratchbuilt his locos while he was a tool room inspector at the Glen El Martin Company in Maryland and General Electric, I believe in the Philadelphia area. They are unique. I have always wondered what became of them after Bill passed away some years ago. GE did a spread in one of their company newsletters about Bill when they found him working on his Big Boy on his own time in their shop. GE thought it was a credit to Bill that he had such an interest in fine machine work and were proud of him. I own the mechanism for a 2-8-0 that he started and never completed.
Joe
Joe
Speaking of Martin (two n's and an L), my father was a test pilot there. I landed the Cub on the airport after the factory shut down.
Thanks for the correct spelling. When I looked at my spelling I knew it was wrong. I live about 1/2 hour from their plant Near Essex MD and remember seeing their flying boats flying over my house in east Baltimore when I was a youngster. Bill Hoffman was also a test pilot during WWII and built his own airplane in his parents barn when he was a young man. He told me when it was finished he took off from the farm and using the PRR Mainline as a guide flew it up toward Philly and back. I don't think you could do that today!
Joe
Joe
I have a fair amount of experience with live steam. Mostly 7.5" gauge and #1 gauge.
Some 0. One of the things that happens is the smaller the model the more difficult it is fitting a you need into the allotted space..boiler, firebox, fuel and water.
This one is odd in that the flame seems to be in the tender..or the nozzle is at the end blasting into the "firebox". Couple of things. The last thing you want to worry about is two-rail or three-rail. You would be certifiable to operate this indoors. Derail, tender disconnects, you have a blowtorch.
I am guessing by the lack of discoloration that this has not been fired other than a test before it went on evilbait, but that is just a guess.
The other reason you don't want to worry about insulated drivers (or wheelsets)...heat. Fire. Flame. Plastic.
And unless I knew he builder, or about him, and his skill (like you don't want that boiler getting to the point of safeties going off) and the boiler goes off instead. What kind of solder? Melting temperature?
Might be just fine. No problem.
But somebody would be stupid to fork out what, 6.5K for a possible pig in a poke.
Usually to finalize the deal, owner/seller would fire and run the engine for a prospective customer...from cold.
It needs some kind of electrical current to run. Looks like a speed control in the tender. Unless that's a shutoff in case derail or tender disconnect.
robert. wrote:It needs some kind of electrical current to run. Looks like a speed control in the tender. Unless that's a shutoff in case derail or tender disconnect.
Serious comment, right? Just checking before I respond.
I know stem makes it move. But I have no clue what that little motor is mounted inside the tender
A few years back when I belonged to the TCA (when there were a fair number of O scale [as in 2R] sellers/dealers that attended York), It was not unusual to see 2 or 3 live steam locos at any given show. They were either 1/24 or 1/32, and most always very nicely done. If I were looking, I would start there, but I already have enough "vices"!
Pretty typical...all the externally visible valve gear is a dummy setup. Stephenson is what is there. Not even certain it is reversible. Scary is the rear set of wheels on the lead truck. Look closely. No way this is going to reliably stay on the track. Still not sure on that motor. Red wire goes through tender floor, but under shot of tender shows...no wire.
Jack screw indicates possibly throttle, or maybe flame, don't think reverse.
