Re: Help With 3 Rail Locomotive Conversion
2railjon wrote:Can anyone share who does 3 Rail locomotive to 2 Rail conversions? It a Weaver 4-4-2 and I have a complete wheel, driver, tender set in 2 Rail from Sunset if that will aid in conversion.
Thanks!
Joe F. who posts here does conversions but those usually entail the creation of drivers. If you can just swap out the drivers, that's the only bit that's got some challenge to it. Rest should be pretty straightforward.
Which 4-4-2?
Weaver model with Sunset parts? Might be a bit more problematic than a screwdriver job.
PM Joe and see what he says.
Before getting carried away, disassemble the two, and attempt a trial fit. Weaver and Sunset may be thousands of miles apart, but their Korean builder probably sleeps with himself.
Do you have two complete models, or just the mechanism for the 2-rail?
2railjon wrote:Anyone have Joes user name here?
I’m not finding it. Thanks!
Here you go Jon.
rrjjf
With regard to using different drivers to convert a 3 rail model to 2 rail operation you will probably have some problems with the crankpins and rods. Most 3 rail "scale" steam model incorporate an odd hollow eccentric crankpin that a metric screws goes through into the driver's crankpin along with some spacers and sleeves. IMO, much easier with a lathe to convert the 3 rail drivers that are made to use with the model's rods to a scale profile.
Joe
Joe
2RailJohn
I tried reaching you on the phone number you sent to me and got a mechanical message that the phone was not in service.
Joe
Joe
- rex desilets
Lovely, lovely cars. Are they scale length?
