https://www.ebay.com/itm/ATCHISON-TOPEK ... SwkvFaV50T
Peter
Is this a Varney 10 Wheeler?
herronpeter
Re: Is this a Varney 10 Wheeler?
Here's another one https://www.ebay.com/itm/Varney-O-Scale ... SwMYRaWDFk
stephen neill
Yes, but it could have been sold by General Models or All Nation. It is a fairly early version. The cover on the gear seems odd to me; can anyone comment? The second one is also the 10 Wheeler, but it is a later version.
Steve
Steve
Did not know there were two versions. Differences?
The drivers and gearbox appear to be Lobaugh. If insulated, then for me it would double its intrinsic value (to maybe $125 or so). But the seller probably has a $400 reserve.
There are at least three on eBay as of two minutes ago.
stephen neill
I believe the kit changed in various ways over the years as it went from Varney to GM, AN, and Babbitt (2 owners). The original cast boiler was done by Adams & Sons, after they went out of business, surely AN would have run out of the supply of boilers they got from GM, so someone else would have done the later castings. But more important, I think Babbitt (first owner) made some changes. Look closely at the running boards, particularly at the back of the second one; It looks like they are much thinner than on the first one; sheet brass?
Steve
Steve
Oh, you. Are correct. George modified all the masters, removing running boards.
They look better with Lobaugh drivers, but the AN drivers are actually quite close to the B&O drivers. And Boyce went to NWSL Gears.
herronpeter
Regarding the gearbox, my first though was it might have been run on 3 rail track and was flattened for clearance?
Peter
Peter
Users browsing this forum: up148 and 49 guests
