The Black GG1
The Black GG1
Postby webenda » Fri Jan 05, 2018 11:58 pm
Lionel 6-18343, First Test
Weight: 6 lbs, 8.7 oz
Test Track: Lionel O-31 Fastrack, 31 x 46 inch oval.
Power Source: Lionel CW-80
Slow (almost stalling on curves)
12.2 Vrms, 3.3 Arms, 24.43 sec / lap, Speed: 14.2 scale miles / hour
Fast
14.2 V rms, 3.3 A rms, 3.58 sec / lap, Speed: 96.7 scale miles / hour
Wicked Fast (inside wheels off the track, GG1 flew off the track several times.)
15.3 V rms, 3.6 A rms, 2.92 sec / lap, Speed: 118.6 scale miles / hour
Re: The Black GG1
Postby Roy » Sat Jan 06, 2018 3:18 am
webenda wrote:Lionel 6-18343, First Test
Yikes! How did you protect the finish?
Re: The Black GG1
Postby Seaboard Air Line Fan » Sat Jan 06, 2018 6:13 am
That's a big jump in speed for such a small change in voltage :shock:
Re: The Black GG1
Postby webenda » Sat Jan 06, 2018 8:00 am
I placed the test track on the bed. GG1 landed on the quilted comforter, except once it slid across the plywood shelf that holds the power supply. The paint and decal seem to be very durable, no obvious damage from the slide.
Re: The Black GG1
Postby G3750 » Sat Jan 06, 2018 11:33 am
Looks good, Wayne! I take it this is a post-war version (i.e. semi-scale)?
Re: The Black GG1
Postby Roy » Sat Jan 06, 2018 11:39 am
I suspect they bake the paint at the factory. I know no other way, to give it that toughness.
Re: The Black GG1
Postby webenda » Sat Jan 06, 2018 7:11 pm
See echo below (George's post repeats everything that was here.)
Edit 1: removed post to avoid unnecessary repetition. :D
Re: The Black GG1
Postby G3750 » Sat Jan 06, 2018 7:16 pm
G3750 wrote:Looks good, Wayne! I take it this is a post-war version (i.e. semi-scale)?
A picture is worth a thousand words...
Lionel's scale version is 20 inches long and the minimum curve is O-72.
Mine is 14.5 inches long and the minimum curve is O-31.
Most Recent Catalog for mine was, "Classic Trains Vol. 1 2001."
As for "Post War" it does have "PW" printed on it but it is not really a post-war era model (1945-1969.)
Yes, a picture is worth a 1,000 words. That's what I thought. I realize "post-war" is an improper term. Was this one of the "Post War Celebration" series?
Looks good whatever the precise terminology is.
Re: The Black GG1
Postby webenda » Sat Jan 06, 2018 7:36 pm
G3750 wrote:Was this one of the "Post War Celebration" series?
Yes it was.
Re: The Black GG1
Postby chuck » Sun Jan 07, 2018 8:11 am
Traditional GG-1 was a great example of selective compression. The engine looked good running Madison cars or Lionel's 16" aluminum sets. And all of it could run on O-31 without looking silly.
Williams scale GG-1 can navigate O-42 but there can't be anything within 4" of the track or it will take it out. It doesn't look "bad" on O-72 but it's not pretty either.
Re: The Black GG1
Postby Roy » Sun Jan 07, 2018 11:24 am
It's nice that your 2332 has dual motors and Magne-Traction. The original 2332's had neither. Plus, RailSounds and command control. Also, I think the originals had rubber-stamped striping that wasn't too resilient.
Can you buy some "black" Brunswick green Madison cars, to run with your engine?
Re: The Black GG1
Postby robert. » Sun Jan 07, 2018 2:14 pm
You buy can Lionel's century club gg1 cheap on eBay. Most people try to test them with cab1. They find in wont work and listed it as not running. You can see in their listing photos they never removed the pantographs. With out them installed it wont receive cab1 signals. install them and your good to go or run it conventional.
Re: The Black GG1
Postby webenda » Sun Jan 07, 2018 3:26 pm
Roy wrote:Can you buy some "black" Brunswick green Madison cars, to run with your engine?
Yes, Williams made them in that color.
Re: The Black GG1
Postby Roy » Sun Jan 07, 2018 5:06 pm
Pretty nice looking, although I wish they didn't always stamp lines above and below the windows.
Re: The Black GG1
Postby J. S. Bach » Sun Jan 07, 2018 7:18 pm
chuck wrote: It doesn't look "bad" on O-72 but it's not pretty either.
Doesn't look all that good on O-84 either:
