Anybody use them?
Just for $#!+s and giggles I decided to order a couple of code 148 #6 switches for my planned new layout next year.
Emails indicate my order will be started on early 2018, hopefully I’ll have them soon thereafter.
I told Brad Strong I would be using hi-Rail wheels and he said no problem, he can build them so they will work with my wheels.
I also wanted to compare them to the 6 I built several months ago, to see if what I built was worthy.
Signature Switch Company???
Re: Signature Switch Company???
I use Brad's P:48 switches and my layout has a mix of his and Bill McConnell's O Scale Turnouts. Brad fabricates ties from laser cut sheets of Masonite - they can be painted and stained. I have found Signature Switches result in the smoothest rolling of wheel sets. I've ordered a Proto:48 #8 double crossover from him for my next layout.
...gregg
...gregg
Thanks Gregg! The few photos I've seen of them show they are well built.
Bob, I've bought four special switches from Brad. He builds a fine product indeed. He is kept busy and as such the turnaround time may be longer that your expecting, but worth the wait.
Here's a photo of a couple pieces he built for me....the crossing has one 30" radius curve over a straight leg...this feeds a matching 30" radius switch and I had Brad build this with a specific track center which was needed due to the existing tight dimensions of my small shelf yard and tunnel through the mill building. He made it so precisely...basically a drop in.
From everything I've seen, Brad does a great job. I gave him a rather large quanity of rail at OSW with the intention of having him build a bunch of turnouts for me. I still plan on doing it.
Having said that, there is is third option for ready to lay turnouts, double-slips, crossovers, etc. His name is Pete Mottershead. What I like about Pete's is not only the quality but the fact he uses individual ties and spikes everything down. No glue or solder. Take a look if you like. He told me he will be at the March Meet in Chicago. http://specialtytrackservices.com/
That's some fancy footwork there Robert
Thanks Jay, I've bookmarked his site.
Got my Signature Switches yesterday:
The 6 I built are close, but Brad's look fantastic. They appear to mate up to ME and Atlas track just fine.
I may end up using the ones I built in my yard and use Brads on the mainline. Means I have to build 4 more but I feel I can do it, even though I've been having a lot of pain in my hands over the past year due to what the doc says is arthritis (don't know how she knows without running a test
Means having to buy more of these vice building my own.
Bob...glad to see you tried Signature Switch...Brad does built a very precise switch.
Robert, yeah, I'm impressed!
Question, he laminates(?) the ties to the track. How do you put Atlas track connectors on, simply cut the last tie loose?
DRIFT ON
This week has been tough. Thought I had the flu but I think it's some kind of cold. Not feeling 100% but not bed-ridden either. All the symptoms of flu (fever, cough, runny nose, sore throat, sluggish) except aches and headache. Haven't lost my appetite, had tacos the other night!
DRIFT OFF
The switches I made came out well dimensionally compared to Brad's, mine are just a tad shorter on the diverging/straight end but shouldn't pose a problem.
DRIFT ON
DRIFT OFF
He leaves clearance for rail joiner so you do not have to cutaway anything.
Funny I started thinking I might be getting the Flu also...my nose started running and was all but non stop...until it stopped...go figure.
There is another.
What I like about Pete's is the fact everything is spiked down to individual ties. He is probably the most knowledgeable person I know of on the subject.
Having said that all three of these guys do great work and you can't go wrong with any of them.
You'll be hearing more about him soon.
