Similar topics are being posted, but I'd like some advice on what to lube on steam power specifically.
I'm really curious about valve gear and the occasional squeaks they produce.
I keep proper lube in my gearboxes and do not expect to be opening them up very often.
When I put a locomotive upside down in my foam cradle, I oil axle bearings, clean drivers, and most recently a bit of oil on anything else that's in motion during running periods.
Steam Power...what to lube?
Re: Steam Power...what to lube?
Robert,
That sounds about right. I use Labelle light oil on my mechanisms.
Joe
Joe
Robert,
I do about the same thing, I also look for parts that get bent easily.
Another thing to look for is wiring issues that might occur whenever the engine is picked up, turned over. I wouldn't open an engine up just to check (thereby inducing more failures), but anytime stress is placed on a connector or wire (like connecting/disconnecting) that's a potential for problems.
One of my civil servant jobs was writing planned maintenance procedures for Navy electronic equipment, maybe I need to write some procedures for maintaining my locomotive fleet!
Things we looked at when writing procedures were:
1) Are you doing more harm than good...is it really preventing anything? There was a procedure to spray oil on an air filter on an AN/UYK-20 computer. The oil was getting sucked into the computer and causing problems and a mess. We also had a procedure to open and inspect the cabling inside the computer, as it turn out this was causing a ribbon cable to fail prematurely.
2) Use common cleaners and lubricants, keep the amount of hazardous material to a minimum. Settle on a cleaner and lubricant and stick to them (don't end up with a cabinet full of different materials). This was a must on ships as they needed to keep hazmat to a minimum for storage and disposal. We should do the same in our homes.
The biggest issue I have is cat hair. I can't seem to keep the rascals off my layout or stop them from shedding. As a result, there's strands of hair on the outer surfaces of the models and they also get wrapped around the axles. Over time it builds up and causes problems. Carpet lint is also a problem for those that have a carpet layout.
One thing I find that squeaks is the draw bar, a drop of oil will help.
Valve gear can and will wear out without lubrication. I use SAE 30 on all axles, crankpins, crossheads, and valve gear pins. The pin that holds the eccentric rod to the crank will go quickly without lubrication.
