First Time I've Ever Seen......
Postby E7 » Tue Oct 24, 2017 2:44 pm
https://www.ebay.com/itm/Overland-EMD-F ... SwtKtZ4mYH
an Overland F3 done up correctly for the PRR.......well almost correctly! :mrgreen:
Not as built because they had coupler doors from the factory, but those were ultimately removed. The steam generators which are almost always left on these models (they were ALL freight engines) have been replaced with the supplied correct blank panel. So WHAT pray tell is the problem? The first PRR order of F's (3 ABBA sets) had their A's numbered 9500 thru 9505. This one is numbered 9513, which would have had LOW fans, as only the first order of F's sported HIGH fans.
Real easy to fix!
rex desilets
Re: First Time I've Ever Seen......
Postby rex desilets » Tue Oct 24, 2017 4:50 pm
Relieved that I am therefore not tempted to bid
Users browsing this forum: Google [Bot] and 47 guests
