Norfolk and Western Derrick Car 1902
Postby webenda » Fri Aug 18, 2017 8:45 am
Image size 2048 x 1155, open image in new tab or save or copy image to see large version.
A Norfolk and Western derrick car and its crew were photographed in Bluefield, West Virginia, in 1902. Platform cars carried derrick cranes used for heavy-lifting duties (for example, bridge replacements and repair) and to move derailed rolling stock.
Re: Norfolk Southern and Western Derrick Car 1902
Postby Rufus T. Firefly » Fri Aug 18, 2017 9:01 am
Lots going on in that photo...
What kind of flat car is that??? Side sills appear to be made up from a framework of 4 pipes/rods with the outside truss rod centered in the end plate.
Stiff leg derrick but maybe with a swivel? 2nd or replacement derrick arm on the flat car.
What's that at the other end - a winch? Use with the derrick or stand alone for other uses?
Postby MurphOnMillerAve » Fri Aug 18, 2017 3:53 pm
The building in the foreground, behind the men, interests me - such a grand, handsome structure , yet such a crummy porch and nearly absent footing for it and its steps. Odd, to me.
Wolf
Postby Wolf » Fri Aug 18, 2017 5:21 pm
The way I read the picture is that the railroad runs in a cut that was
either just deepened or widened and that the crew with the derrick
is placing stones for the new retaining wall (as can be seen in the
background). Once the new wall is in, I would assume that the
building behind the flat car would get a more-proper set of steps
and underpinning for that porch....
Take care,
Wolfgang
Postby MurphOnMillerAve » Fri Aug 18, 2017 5:39 pm
I would imagine you are right, Wolf.
Re: Norfolk and Western Derrick Car 1902
Postby webenda » Fri Aug 18, 2017 11:41 pm
What is that thing floating above the electric/telephone pole?
[url=https://flic.kr/p/XMtQ2U]Image
Postby Roy » Sat Aug 19, 2017 1:17 am
webenda wrote:What is that thing floating above the electric/telephone pole?
It looks like a space capsule.
Postby Tom Dempsey » Sat Aug 19, 2017 2:10 pm
Clown Car from Outer Space?!
Postby Rufus T. Firefly » Sat Aug 19, 2017 4:26 pm
An electrical light - there are at least two more in a line in the photo........
Postby webenda » Sat Aug 19, 2017 7:19 pm
Aha! :idea:
They are a form of carbon rod arc light called a "Moon Light." They were self-igniting (the fuse that got them started had to be replaced before they could be ignited the next night.)
Image[/url]
LIFE EXPECTANCY
Carbon rods in the first Moon Lights lasted two hours.
In the 1890s the carbon consumption of the rods was slowed down considerably by enclosing the lamp in a gas tube, which increased the life expectancy of the carbon sticks fivefold – enough to make the rods last all night.
Later arc lights could burn for 100 to 150 hours (4 to 6 days) without replacing the rods.
Reference: http://www.lowtechmagazine.com/2009/01/ ... 1800s.html
Thank you, Rufus, for the clue.
Postby rogruth » Sat Aug 19, 2017 9:00 pm
I actually saw a very similar car working on the the old Wrightsville and Tennelle in Wrightsville, GA in the mid 1980s.
The W&T became part of the SRR and then NS. It is still in use.
Postby Mitch » Sun Aug 20, 2017 7:42 pm
As a kid, helpin' clean up at the local Drive-In theater, I remember carrying out burnt carbon rod stubs from the two big projectors mounted to the cement floor. The rods burned long enough to show 1 reel of the movie, the second projector set up to go after intermission. The carbon rods make a pretty darn bright light.
Users browsing this forum: No registered users and 66 guests
