For you CLW fans...........
herronpeter
Postby herronpeter » Sun May 21, 2017 9:11 am
Re: For you CLW fans...........
Postby Tom Dempsey » Sun May 21, 2017 12:31 pm
Very good condition?
Postby ScaleCraft » Sun May 21, 2017 12:46 pm
Tom Dempsey wrote:Very good condition?
What, you don't like mismatched joints, popped solder joints, massive....corrosion or something blue-green and growing....and unless this San Mateo Seller just missed it (unlikely) absolutely no parts to complete.
Like, oh, the other chassis...all roof appliances (including fan)...you can see the locating marks on the roofs, but no parts...not even a motor..."Condition: New: A brand-new, unused, unopened, undamaged item"
rex desilets
Postby rex desilets » Sun May 21, 2017 12:58 pm
Also, isn't that the cast nose that Turner dislikes? :roll:
Postby ScaleCraft » Sun May 21, 2017 1:05 pm
rex desilets wrote:Also, isn't that the cast nose that Turner dislikes? :roll:
I thought he hated them all....did not know that that particular specimen in San Mateo was the only one...he even hates sand cast FT Bulldog Noses.....and Helio Couriers.....
Postby bob turner » Sun May 21, 2017 1:56 pm
Not a fan of the Courier - except when it is used for jungle resupply/rescue. Then it shines. Few know how to properly fly them.
The PA nose - and the E-7 nose - a thing of beauty and grace when properly done.
This offering? The trucks and gearboxes are worth $150. The "B" body is ok, and the aft shell of the A is usable. The green stuff comes off quickly. Re- soldering is not difficult. The nose is semi- hopeless; wrong shape, wrong contours, and worst of all, not long enough by a bunch.
I figured my name would come up - that is why I did not post earlier. Off to the airport.
Postby rogruth » Sun May 21, 2017 2:35 pm
How come it's not RARE? :roll: :roll: :wink: :wink:
Postby Rufus T. Firefly » Sun May 21, 2017 2:43 pm
ScaleCraft wrote:....corrosion or something blue-green and growing....
That's easy to deal with; some 20-30% acetic acid for 20 min and a methanol wash and its gone, and ready to paint. Or, use 5-10% muriatic, rinse and go paint.
GreggL
Postby GreggL » Sun May 21, 2017 3:06 pm
Rufus T. Firefly wrote:That's easy to deal with; some 20-30% acetic acid for 20 min and a methanol wash and its gone, and ready to paint. Or, use 5-10% muriatic, rinse and go paint.
As one who is just learning to paint brass, is there a reason for methanol as opposed to another rinse, such as soap/water/isopropyl/etc? My 20 hours of college chemistry are too distant to sort this one thru.
...gregg
Postby ScaleCraft » Sun May 21, 2017 4:45 pm
Note, from my post earlier:
Not. Yes, you can do that, yes you can clean it, yes you can resolder the ends, yes you can find all the missing parts.
""Condition: New: A brand-new, unused, unopened, undamaged item"
Not.
That's why I quoted it off the listing, figuring the folks who might just say "no big deal", but it isn't "Condition: New: A brand-new, unused, unopened, undamaged item"
Postby Rufus T. Firefly » Sun May 21, 2017 4:54 pm
Not.
I did not state "no big deal".
I'm only supplying the information on one aspect since all too many do not how to address that specific and run away screaming like little girls when confronted by copper corrosion on brass.
The rest is immaterial to me - it's a pile of scrap metal and worth only that to me....if I was collecting for the scrap dealer, and I'm not
eBay used to have a mechanism to report a fraudulent listings.....knock yourself out chasing that down.
Postby ScaleCraft » Sun May 21, 2017 5:28 pm
Rufus T. Firefly wrote:eBay used to have a mechanism to report a fraudulent listings.....knock yourself out chasing that down.
Key words..."used to". Is it fraudulent? Who knows. Does it match the description? No. Since I never did any CLW, at all, did that set come with all the frames, sideframes, drives, motors and detail parts in one BOX? Note the lack of a "box" in the listing photos.
Scrap brass, yes. Send the FA nose off to Burner.
'PA-1 & PB-1 Shells + a Chassis with driveshaft & gears'-VG.....at least he got the "a Chassis" part right.
This is a "humor on evilbait" posting, right? And somebody bid on it (once) so it must be a good deal.
Postby Tom Dempsey » Sun May 21, 2017 5:31 pm
Certain sellers always seem to have 1 bid on their wares early on, not that there's anything wrong with that.
Postby ScaleCraft » Sun May 21, 2017 5:49 pm
Tom Dempsey wrote:Certain sellers always seem to have 1 bid on their wares early on, not that there's anything wrong with that.
Didn't say there was. Commenting that one person has bid, so they must see some value (like Burner's $150 for the drives bit).
Postby Rufus T. Firefly » Sun May 21, 2017 5:53 pm
ScaleCraft wrote: And somebody bid on it (once) so it must be a good deal.
All that a bid indicates is that someone, somewhere believes it to be worth that amount to that bidder.
Whether that is a good deal depends on what the bidder(s) may believe.
As it has zero value to me, I will not bid.
Users browsing this forum: Jay Criswell and 36 guests
