Recommendation wanted for wire rope
Re: Recommendation wanted for wire rope
Postby webenda » Sun May 21, 2023 5:27 pm
Walmart sells nylon cord that looks right on Lionel Cranes.
A closer look:
These are the smaller cords on the card. The left one is brown, the right one black.
The upper scale is 1/64 of an inch per division, the lower scale is 1 mm per division where the cord is (0.5mm to the left of the cords.)
The cords are about 1 mm (0.039 inch) in diameter or 1.9 inches in 1:48 scale.
Postby gregj410 » Sun May 21, 2023 6:23 pm
G3750 wrote:Hi All,
wire rope?
#3 picture hanging wire is perfect.
https://www.tractorsupply.com/tsc/produ ... RPEALw_wcB
Country Gray is an interesting choice of cable color.
In most steel mill pictures, everything looks black.
Looks about the same color as picture hanging wire :wink:
Postby healey36 » Sun May 21, 2023 8:26 pm
I’ve used stretchable cord from the jewelry dept. at Michael’s for stringing telegraph poles. It works pretty well, and has enough give to save it from overly exuberant spectators.
Postby webenda » Sun May 21, 2023 8:31 pm
gregj410 wrote:
webenda wrote:Country Gray is an interesting choice of cable color.
I agree. The picture hanging wire in the photo is galvanized steel wire. The normal zinc-plated coating is dull gray in color with a matte finish.
Postby G3750 » Mon May 22, 2023 11:02 am
webenda wrote:Walmart sells nylon cord that looks right on Lionel Cranes.
A closer look:
The upper scale is 1/64 of an inch per division, the lower scale is 1 mm per division where the string is (0.5mm to the left of the cords.)
Strings are about 1 mm (0.039 inch) or 1.9 inches in 1:48 scale.
Wayne, I applaud your resourcefulness!
Thank you.
Postby robert. » Mon May 22, 2023 9:29 pm
Look into dacron string/thread. I use this for making bow strings. It comes in many colors.
