My Lionel General Bash
Postby Roy » Wed Jul 04, 2018 2:29 am
This is my bash, prior to painting. I did very few build photos of this model, so I thought some build details would be more apparent, if I showed it like this.
I started with the Lionel Redwood Valley Express engine, because it was the cheapest Lionel General available. (Please, don't make changes to collectible Lionel pieces.) The tender tank is from a battery-operated O gauge train. The engine boiler is brass.
These are the headlight and smokestack which came with the Redwood Valley Express engine:
Neil
Re: My Lionel General Bash
Postby Neil » Wed Jul 04, 2018 6:25 am
Nice creativity and craftsmanship Roy.
Neil
Postby Roy » Wed Jul 04, 2018 2:05 pm
Thank you, Neil.
Postby G3750 » Wed Jul 04, 2018 3:56 pm
Very nice, Roy!
Postby chuck » Wed Jul 04, 2018 4:01 pm
Wow, nice job. Did you make the steam and sand domes?
Postby Roy » Wed Jul 04, 2018 5:15 pm
Thanks, George and Chuck.
chuck wrote:Did you make the steam and sand domes?
No, I just altered them a bit. I didn't like the octagonal bases, so I replaced them with K&S tube. Similarly, I adjusted the height and diameter of the dome barrels. The plastic that the boiler furniture parts is made of is extremely brittle. As I was drilling the bell bracket, it just shattered. I rebuilt the bell in brass, in the same style as the stock part. The bell swings.
Postby chuck » Wed Jul 04, 2018 6:16 pm
Really nice work.
Are you going to try to modify the drivers or possibly use paint to make them less "solid". That's always been my biggest beef with the model (or any of the PW stuff with spoke drivers that are actually solid.
Postby Roy » Wed Jul 04, 2018 7:57 pm
chuck wrote:Are you going to try to modify the drivers or possibly use paint to make them less "solid".
I wasn't planning anything more than painting the spaces black. Given the drivers half-plastic, half-diecast construction, it looks like it would be quite time-consuming to open up their spokes. I haven't tried it yet, anyway. It seems likely to be easier to scratch build new drivers, but that's beyond the scope of what I was trying to do.
P.S. I have a couple of cheapie Lionel mechanisms with similar drivers, with red plastic spoke inserts. To my surprise, I found that there are four spoke spaces on the die cast wheels. The openings on the gear side are different than those on the non-gear side. These wheels would be much easier to convert to fully-spoked, than the General drivers.
Postby Rufus T. Firefly » Thu Jul 05, 2018 8:30 am
Roy wrote: It seems likely to be easier to scratch build new drivers...........
While I've seen how folks do scratch together drivers, it's not commonly done. Suggest that you look into getting drivers from Slaters. Brit profile, but nice and you can add the counterweights yourself.
Postby Roy » Thu Jul 05, 2018 11:04 am
Rufus T. Firefly wrote:While I've seen how folks do scratch together drivers, it's not commonly done. Suggest that you look into getting drivers from Slaters.
Thanks so much for the tip, Rufus. The thing is, I like making things, and modifying things.
With regard to my General, I wanted to show that you can make a nice 1/4" to the foot scale model of an American 4-4-0 just using what you get on the General. I re-used the original motor and gears, drivers, cab, etc.
It would be very nice if Lionel would do likewise, and offer a scale 4-4-0 at a popular price. They could continue to make the General for those who would have them.
Postby Rufus T. Firefly » Thu Jul 05, 2018 2:11 pm
Roy wrote: and offer a scale 4-4-0 at a popular price.
Define reasonable. Van Pelt economics can't apply here
Scale and accurate, and also in 2-rail; they will sell.
Postby HONDO74 » Thu Jul 05, 2018 2:48 pm
Back in 2011 Lionel did make the "The Lincoln Funeral Train" with a scale engine.
Lionel Railroader Club Exclusive "The Lincoln Funeral Train"
https://www.youtube.com/watch?v=0cMA_5aN7b8
Postby Roy » Thu Jul 05, 2018 4:52 pm
Rufus T. Firefly wrote:Define reasonable. Van Pelt economics can't apply here
Made the same as the General; i.e., plastic injection-molded body.
Postby G3750 » Thu Jul 05, 2018 5:01 pm
"Reasonable" does seem to be the heart of the matter doesn't it?
The SMR locomotives were jewels, true works of art, but eeeyyyowww the prices were out of my galaxy. :lol:
Postby Roy » Thu Jul 05, 2018 5:04 pm
HONDO74 wrote:Back in 2011 Lionel did make the "The Lincoln Funeral Train" with a scale engine.
Thanks, Hondo. I'm not drawn to the lines of that engine, plus - it was a more expensive, special-order-only item.
