Bob Turner Lost Plastic Process
Postby E7 » Sat Jun 04, 2022 10:04 pm
Bob, As you are no doubt the forum Guru on turning plastic bodies into brass, how about a topic on everything you know/have learned on the process. Things that might noe be obvious like putting in tabs/blocks to screw the sections together. I am hoping to try this if I live long enough! Thanks for any input. :mrgreen:
Re: Bob Turner Lost Plastic Process
Postby bob turner » Sat Jun 04, 2022 10:55 pm
I have had expert help, and have wasted a few models along the way. Dennis Mashburn was the master - he had a vacuum flask big enough for 1/2 of an entire PA body. We learned very early on that a "double burnout" was required with MTH bodies.
(Before I go further, let me mention that I got permission to use plastic parts for such efforts from MTH, Atlas, and Scott Mann.)
A "double burnout" is simply keeping the investment (the plaster - hope my terminology is correct) at burnout temperature twice as long. That way all the ash is vaporized.
Then we learned to be careful with shock cooling. Ordinarily, after the metal is poured, you pitch the plaster into cold water, both solidifying the metal and blowing the plaster into little chunks. A big Diesel body needs a more uniform cool-down to avoid serious distortion. But then the plaster has to be chiseled off.
Jay C is also an expert at this - he has friends in the business, and did the Erie-built nose for me.
None of this is cheap. I spent around $400 (when fuel was $2.25/gallon) to do the Erie-built. It would have been more if I didn't have "connections."
What, specifically, are we thinking of?
Postby E7 » Sat Jun 04, 2022 11:42 pm
The old Roco C-Liner.of which I have several bodies. Probably shooting for 2 A's.
Postby bob turner » Sun Jun 05, 2022 11:25 am
Yes - check with Jay. You will have to find a suitable joint, probably at the center door. Saw in half with the skinniest blade you can find, then merely glue plastic tabs on the inside of the shortest piece. Any changes to the body can be done with candle wax or plastic - I would stay away from Bondo, although I am sure that would work ok.
Then just ship to the foundry or follow Jay's recommendations. I would expect about $300 per unit - failures can occur, but these folks are good at what they do. Expect 1/2% shrinkage - not enough to detect by eyeball.
Now if only I could find a sand casting operation . . .
Postby ScaleCraft » Sun Jun 05, 2022 5:16 pm
One of the car shows, Bitchin' Rides, used a sand casting foundry in south (?) Salt Lake. So I know that the process is still out there.
Postby E7 » Sun Jun 05, 2022 8:46 pm
bob turner wrote:Yes - check with Jay. You will have to find a suitable joint, probably at the center door. Saw in half with the skinniest blade you can find, then merely glue plastic tabs on the inside of the shortest piece. Any changes to the body can be done with candle wax or plastic - I would stay away from Bondo, although I am sure that would work ok.
Thanks! The project has to go on the shelf until I get past some medical issues. If that happens I wull contact Jay. I actually have a cab that I got on Feebay way back. Wherever it was done, they did a beautiful job. The only flaw is one of the steps at the bottom of the pilot was broken off, and there are no tabs. I think I will try Bondic to add tabs. That stuff is supposed to be very strong. I might try and cobble up coupler doors.
Can't help on the foundry, but if I hear of one in the future, I will pass the info. on.
PS: Wouldn't you need a tab on each half?
Postby bob turner » Sun Jun 05, 2022 9:49 pm
You don't need tabs at all. Just screw brass plates inside before soldering the halves together. Tabs just cut the work in half.
Before burnout, you can attach tabs with plastic cement, or candle wax. Very little structural strength is required. Fill the pillot with candle wax, carve the doors with a toothpick, and press on.
Postby E7 » Tue Jun 07, 2022 9:39 pm
What I envision is gluing short rectangular solids that match up when the cab and body are aligned. Put a screw through them (one on the roof, 2 on the sides. Run a sheet metal screw through them (might need to drill a pilot hole for the screws). Once they are screwed together, solder the seam and it should be pretty solid. A coupler door would have to be built out from the pilot. They were a trapezoidal shaped affair.
Screwing together 2 parts sort of similar to the old All Nation halves, only cab and body rather than halves.
I'm having trouble picturing/understanding what you are describing.
Postby bob turner » Tue Jun 07, 2022 11:22 pm
Practice with a junk plastic freight car - say, an ice car. Saw it in half at the center of the hinged doors.
Now pretend you had it cast, and fasten it together again, using inner panels of brass, and countersunk brass 2-56 screws. Then fill in any gaps with Bondo - simulating what you would do with solder. If the saw kerf makes anything look distorted, glue a spacer in there.
In my case, the MTH stainless grills were important, so before casting I glued plastic just a teeny bit thicker than the saw kerf.
I think I have photos in Shutterfly of the finished products. Need the big computer . . .
Postby E7 » Wed Jun 08, 2022 3:19 am
I'm thinking a miter box and the thinnest saw blade I can find. The box will take care of the "precision" factor. I have used it when I needed to cut ABS pipe dead square. Biggest question might be where to cut.
Postby Jay Criswell » Wed Jun 08, 2022 8:29 am
One thing I might add at this point. Stripping the paint, prior to burnout, is advised. I say this because paint frequently leaves ash and ash makes for terrible castings.
Postby E7 » Wed Jun 08, 2022 9:03 am
Thanks Jay! Hope to be talking to you about this in the not to distant future.
Postby Jay Criswell » Wed Jun 08, 2022 10:29 am
Rich,
Before you chop anything up, it would help to know the projected dimensions of the parts we want to burnout and cast. Length, width, and height. once this is know we can run it by David to verify the parts will fit in his flasks. Once we know this he may be able to provide an estimate of the cost.
Another item to keep in mind, not all plastics burnout the same and results may vary. David will make no guarantees.
Postby bob turner » Wed Jun 08, 2022 12:17 pm
Agree. You are not chopping the cab off - you are cutting to make two smaller pieces. Make them as equal length as possible.
A chop saw is not necessary - the cut need not be square - just cut in places where the new joint will not visually stand out, or where you can get a sanding block in to smooth the joint. A jeweler's saw leaves very little kerf.
Postby bob turner » Wed Jun 08, 2022 9:18 pm
Repeating my photos - this one was "shell-cast" in one piece. The foundry did not know about double burnout, so used some kind of media to clean out the investment, resulting in much loss of detail. It was a worthy experiment, and even though costly, I do not regret doing it.
Shell cast is when you splatter plaster all over the master, rather than pouring it into a vat. No, I am no more knowledgable than that.
