Inclined Cylinder
Inclined Cylinder
Postby R.K. Maroon » Mon Jan 06, 2020 6:08 pm
A friend of mine is looking for an inclined cylinder for a 4-4-0, 4-4-2, or similarly sized locomotive. The only one I have ever seen listed in a catalog is an inclined version of the All Nation cylinder for their 4-4-0. This was offered not by All Nation but later by Babbitt. I believe it might have been urethane, but I have never seen one. I would have thought that others might have offered something similar at one time but I have no evidence that anybody ever did.
If anybody has one they would be willing to part with at fair price, or if anybody knows of any other sources or leads, please let me know.
And here, for fun, is C&NW Atlantic 1015 (at some museum preserved, me thinks):
Now that's inclined!
Thanks
Re: Inclined Cylinder
Postby ScaleCraft » Mon Jan 06, 2020 6:49 pm
Contact Garberson. I traded mine for a stock A-N cast cylinder.
Postby webenda » Mon Jan 06, 2020 6:54 pm
Maroon,
Those are not inclined cylinders, these Hackworth cylinders on No. 25 Derwent are inclined cylinders.
Postby R.K. Maroon » Mon Jan 06, 2020 7:37 pm
Wayne, quit confusing the issue with the facts. :|
Postby bob turner » Mon Jan 06, 2020 8:28 pm
Yeah. All you have to do for inclined cylinders is add a shim. But these have a special name, and I cannot remember what it is. Check the Stauffer PRR Steam book - E3 Atlantic. Inside admission?
And yeah - the resin ones are the only ones I am aware of. Making cylinder blocks is not difficult, and really trivial if you have a lathe.
Postby R.K. Maroon » Tue Jan 07, 2020 3:02 pm
Photos of an O-scale inclined cylinder assembly have appeared:
This are believed to be All Nation. It appears from inspection that one could indeed make one of these (or something close enough) by modifying a regular cylinder assembly. I will see if I can get measurements.
Postby rogruth » Wed Jan 08, 2020 3:50 pm
The cylinder configuration in the first photo above is used with inside Stephenson valve gear.
Postby bob turner » Mon Jan 13, 2020 12:52 pm
Finally tried to find proper nomenclature. Best I could do is p.70 of Carleton's PRR Steam Second Look - he calls them "slanted piston valve" cylinders.
Users browsing this forum: Bing [Bot] and 63 guests
