Postby 2railjon » Tue Jan 30, 2018 4:27 pm
rrjjf
Re: Old Rivets & The FOM
Postby rrjjf » Tue Jan 30, 2018 7:05 pm
2RailJon,
When these Sunset 3rd Rail GG-1 models first arrived I was asked by several modelers who purchased them to go over them. I found that the frames were bent and keeping the drivers off of the rails. I managed to straighten the frames by putting a wooden pencil between the car body and the frame at an appropriate location and gently bending the frame using the pencil as a fulcrum. This was a quick fix and improved the operation of these models.
I do not have a high opinion of these locomotives. Look at your frame closely. This may be the problem with your loco.
Joe
Postby 2railjon » Tue Jan 30, 2018 8:27 pm
Postby bob turner » Tue Jan 30, 2018 9:36 pm
I do have a high opinion, but think they need all six axles powered. Ditto the FF2.
rrjjf
Postby rrjjf » Wed Jan 31, 2018 7:43 am
2RailJon.
I also remember shortening the length of the springs under the pilot truck mounting screws. The pilot trucks seemed to be lifting the drivers off of the track.
I never had to disassemble these models. I just slid the pencil between the car body bottom and the frame that holds the drive assembly.
Bob T. IMO These are very nicely done car bodies with lousy drives using cheap motors and all wheels should have been powered.
Joe
Postby 2railjon » Wed Jan 31, 2018 5:39 pm
Postby sarge » Wed Jan 31, 2018 6:49 pm
See if that unpowered main axle isn't oversupporting as well; bloody stupid design having the pilot trucks and an unpowered wheel on opposite ends oversupporting the two driven ones. You'll have to treat each assembly as you would sorting a poorly sprung 4-4-2 steam loco.
Also, the weight is conveniently where it does the least good, over two undriven axles. Can you get some sheet lead under the motors and over the driven axles?
Postby bob turner » Wed Jan 31, 2018 6:59 pm
Sprockets and Delrin chain.
Postby 2railjon » Wed Jan 31, 2018 7:22 pm
Postby robert. » Wed Jan 31, 2018 8:14 pm
Can you fill the shell with shot and epoxy
Postby 2railjon » Wed Jan 31, 2018 9:15 pm
Postby sarge » Thu Feb 01, 2018 7:17 am
Jon, if you've never done that stunt before, don't be tempted to use white glues or carpenters glue (PVA) with shot. I've seen many a model ripped apart as the mass swells pretty friskily over a long period of time.
Postby Rufus T. Firefly » Thu Feb 01, 2018 8:45 am
sarge wrote:Jon, if you've never done that stunt before, don't be tempted to use white glues or carpenters glue (PVA) with shot. I've seen many a model ripped apart as the mass swells pretty friskily over a long period of time.
If wanted, I could send you an ingot of Cerrobend to reshape to where it might fit. I might also find it possible to scrounge up some sheet lead.
Let me know, Jon
Postby 2railjon » Thu Feb 01, 2018 9:15 am
rex desilets
Postby rex desilets » Thu Feb 01, 2018 12:12 pm
Rufus T. Firefly wrote:<snip> I might also find it possible to scrounge up some sheet lead.
<snip>
Amazon.com
