Working Headlights...do you bother?
Postby Robert » Thu Aug 17, 2017 6:54 pm
There was a time when having operating headlights on my locos was a worthy pursuit, but not so much these days. I'm content with one of those MV Products lens and forget the assorted issues with appropriate bulbs, or LED's, resistors and maintenance of same as they go bad and so forth. What say you?
Re: Working Headlights...do you bother?
Postby Rufus T. Firefly » Thu Aug 17, 2017 7:10 pm
Robert wrote:There was a time when having operating headlights on my locos was a worthy pursuit, but not so much these days. I'm content with one of those MV Products lens and forget the assorted issues with appropriate bulbs, or LED's, resistors and maintenance of same as they go bad and so forth. What say you?
For some folks having all he special effects are more important that having an accurate model - I can't be bothered....with the special effects, :roll:
Postby Seaboard Air Line Fan » Thu Aug 17, 2017 7:45 pm
Yes!
With the BPRC receivers I use I can easily wire the front and rear headlights to come on when I change directions. I've been using the 3mm and 5mm LEDs from Evans Electronics, they already have a resistor wired in the circuit and the instructions for the receiver are easy to understand.
The biggest pain is getting the polarity right the first time, I've learned not to make the connections so permanent until I'm sure they're correct.
I haven't wired up any class or marker lights yet because, from what I've read, they were off most of the time (at least for my purposes and operations).
Postby R.K. Maroon » Thu Aug 17, 2017 7:47 pm
I know several modelers who generally never operate their locomotives but to whom having the model "ready to run" is nonetheless important (What is that motor for, after all?). One could argue that it's good for resale, but I think it's mostly just an expected part of model trains for most of us -- locomotive models should run. I see the headlight issue as a corollary or subset of this. If you never run the model, who cares? I will admit further that I will run a locomotive (for a while at least) without a working headlight. But I think the sight of burning headlight is an essential part of the operating experience, especially for continuous (round and round) operation. Further, I find that a constant brightness, directional headlight setup is so much better than a basic "variable with throttle, on in both directions" setup that I will retrofit even my old doorstops with the constant-directional setup.
Here is a test of the first installation I ever did, an OMI modified P5A (the pilot is off for repair in this photo):
Since the locomotive is dual-ended having directional headlights seemed a must. I replaced the original grain-of-wheat bulbs with LEDs. You can get "golden yellow" LEDs now to get a good color -- no reason to put up with the old blue-white LEDs anymore.
Postby bob turner » Thu Aug 17, 2017 8:06 pm
About 25% of the time, maybe less. My first scratchbuilt has an early constant intensity light. My third has mars light and GOW lamps in the class lamp castings. Some of the Lobaugh Mikes have a "golden glow" headlight. I really like those . . .
Postby E7 » Thu Aug 17, 2017 8:11 pm
Put it in the "so what" file. Rather have a non functional light than the way they run the wiring on some steamers, meaning when they drill a hole through the top of the boiler for the wiring to the light. Sort of a Turner no boiler belly kind of thing. :mrgreen:
Postby De Bruin » Thu Aug 17, 2017 8:57 pm
I'm semi-obsessive about working headlights for my locomotives and any of the clubs I have to work on. Since the club doesn't have meters on the individual cabs, the headlights and relative brightness help determine whether we have a wiring problem (since we're in the middle of re-wiring the model boards and their block controls we have a lot of track power issues.) Also I like to watch the completed trains making the circuit on track world, so no headlight equals no joy. This will be especially true in reduced ambient lighting(got plenty of that downstairs too)
Jim got me hooked on the constant brightness circuits, l.e.d.'s, etc. though they do introduce their own issues compared to the old straight wired incandescents, I typically skip them and go with a straight 16volt bulb if there's no room, like a steam engine, or it's an old engine with one of those bug honking open face K&D's.
Postby sarge » Thu Aug 17, 2017 9:38 pm
A couple things make me bother, with my US outline modelling.
First is era. I'd have to look it up again to remember precisely what year, but not long after the war there was an ICC ruling requiring headlights at all times. When I modelled WWII New England, I didn't sweat them. Diesel era modelling, I sweated them religiously.
Second is the fact it is a visual detail. No light is a pretty obvious visual anomaly on a fifties-era loco onwards. Since modelling is all about the visual, I very much bother because it adds to the visual realism, but couch it in the era modelled.
BTW, Robert, drill a little hole in the back of an MV lens, just through the plating will suffice. Then put a small grain-of-rice bulb up to the hole. The effect is astonishingly good.
Chris Rock
Postby Chris Rock » Fri Aug 18, 2017 9:47 am
A guy in our local group named Wes did some research and said the ICC ruling on headlights was in 1954.
I model 1953 and most of the video shots and photos I've seen from that earlier time on the N&W show the headlights off during the day. From what I've seen in photos and videos for N&W lights on would have been a real outlier. Then you see shots from 1955 and later, and clearly in all of the videos and photos the lights are on without question.
My guess is burning lights cost money and was a beancounter decision.
It is high noon on my layout and no need for lights in 1953, not just a matter of convenience.
Postby sarge » Fri Aug 18, 2017 11:40 am
Before the ICC ruling, many railroads and several states required it as a matter onto themselves.
Speaking of research for members of our various groups, I believe Milwaukee required it of all diesels and electrics in their 1945 rulebook, for example. Many of the Western roads that had trackage in Texas (perhaps a universal requirement in Texas?) required it of all their locomotives by 1950. I believe New York State required it before it became universal as well.
So, best advice would be to get a copy of your prototype's rulebook dated to the era you model. Read it to find out and decide then if you care.
Wolf
Postby Wolf » Fri Aug 18, 2017 12:18 pm
The only thing I know is that when we lived near the tracks in 1950-1954,
I saw just about every SP train go by with their headlight on. And in the
case of those so equipped, with their Mars lights on as well. Believe that
was SP policy at the time, reflected in their Rules of Operating Department.
Do also remember watching a light set of F-units travelling west toward Santa
Barbara with the rear red Mars light flashing as we drove up parallel Highway 101
in the daytime in 1953. One hell of a noticeable marker, eh? Certainly drew my
attention to it!
So, if you have personal knowledge of the carrier and/or era that you are
modelling---go with it! And if you have photographic "proof", that's even more
compelling. Just remember it's YOUR (model) Railroad, and you can light 'em
if you want to (sorry, Leslie!).....
Take care,
Wolfgang
Postby up148 » Fri Aug 18, 2017 12:33 pm
+1 on lighting. I try to have the most accurate models possible, since I'm trying to recreate the prototype in miniature. That being said, I could give a hoot about smoke and will never have it. Just a rivet counting fool. :) :) :)
BH
Chris Rock
Postby Chris Rock » Fri Aug 18, 2017 12:37 pm
Hey guys,
Yes, I know that different railroads had different rules. That is why I specifically referenced N&W and NO OTHERS.
Postby Rufus T. Firefly » Fri Aug 18, 2017 12:42 pm
sarge wrote:So, best advice would be to get a copy of your prototype's rulebook dated to the era you model. Read it to find out and decide then if you care.
I shall have to peruse one of my CVRR rulebooks. Sadly, I do not have any from the 19th century.....yet.
Postby R.K. Maroon » Fri Aug 18, 2017 1:28 pm
Interesting discussion. Thanks to Chris for raising the question regarding daytime headlight operation and historical era. Having grown up past the "headlights on" dictum, it never crossed my mind that trains ever ran without their headlights burning (at least past the electric light era -- not lighting oil lamps is more understandable). As a maintenance issue though I imagine that there was non-trivial cost to replace all those bulbs regularly.
I will agree with my brother though -- turning down the lights and watching trains coming around the bend and heading down the tangent is a lot of fun. Even better when the observation goes by with a lit drumhead.
Users browsing this forum: No registered users and 78 guests
