Door stop or fixer upper.............
herronpeter
Re: Door stop or fixer upper.............
Looks oddly familiar...........as if it has graced this forum in the past.....
herronpeter
I never heard of that make of locomotive before so I added it to my "let's see what the guys at MTJ have to say" list!
P
P
herronpeter wrote:I never heard of that make of locomotive before so I added it to my "let's see what the guys at MTJ have to say" list!
P
Adams has been kicked around here quite a lot. Should get the full info on this shortly from somebody...
Rufus T. Firefly wrote:Should get the full info on this shortly from somebody...![]()
OK, I'll bite. This is a Siebers Bros. E3/6, which is comprised of Adams and Son castings for the nose, roof, ends, and truck sideframes and Sieber Bros sides and chassis. Adams and Son gets the credit now, as they put their name in the castings, but it was Siebers Bros. that marketed the model. Unfortunately, the axle gears in these are undersized for the load and there was a flaw in the worm shaft support (or lack thereof), so the drives are problematic at best. Note that Pomona Valley and later Fernando Valley also marketed an E3/6 using the Adams and Son casting set (which could be bought separately direct from A&S). The PV/FV units have their own unique drive, and those built by modelers from the castings alone (or those with their original drives replaced) also can have unique (and at times odd) drives, so these are seen in a variety of configurations.
- rex desilets
Damn! you're good!
Thanks for the kind words, Rex. I wrote a column in this model in O Scale Train last year, so you might say I was loaded for bear on this one.
This 3 railer finds Jims articles for OST to be informative and interesting,
The same is true for the whole magazine.
If you don't know, Rufus and Sarge and several other posters here
make OST great even for this 3 r guy.
IMHO there is a lot of good stuff in OST.
I think I am repeating myself, myself.
At the risk of offending some of you connoisers (intentional misspelling) of ancient locos, I'd like to add an option: Door Stop/Fixer Upper/Anchor
E7 wrote:At the risk of offending some of you connoisers (intentional misspelling)
try: "commonsewers"
might also be a blunt weapon of choice for hand to hand combat
herronpeter
Surf casting weight during a storm................??!!
Peter
Peter
herronpeter wrote:Surf casting weight during a storm................??!!
Probably end up hitting yourself over the head with it trying that sort of stunt,
Sold for $427. I am "wowed!"
Wow is right. Even with the recent uptick in doorstop prices, I would not have expected this one to go for much more than $200, especially given that the drive may need some serious work and we know for a fact that the sides are all bent up. But eBay is full of surprises. I do recall an AB set of Wentzco FTs going for around the same price not that long ago. The funny thing is that in each case it takes two people to bid it up that high. No telling what the high bid actually was.
Users browsing this forum: No registered users and 49 guests
